32.768KHz RC Oscillator Configuration for BLE central
Hi there,
I am developing a BLE dongle on nrf51822. There is no external 32.768KHz crystal oscillator on my customized board(only has an external 16MHz oscillator). so I have to use the on-chip 32.768KHz RC for softdevice.
However, I am confused with the LFCLK source settings.
I set the following values for the nrf_clock_lf_cfg_t variable and set into softdevice by SOFTDEVICE_HANDLER_APPSH_INIT function.
#define NRF_CLOCK_LFCLKSRC      {.source        = NRF_CLOCK_LF_SRC_RC,            \
                                 .rc_ctiv       = 1,                                \
                                 .rc_temp_ctiv  = 1,                                \
                                 .xtal_accuracy = NRF_CLOCK_LF_XTAL_ACCURACY_20_PPM}
But from the devzone forum, a lower calibration frequency setting seems more popular, the parameters are set as below,
                                 .rc_ctiv       = 16,                                \
                                 .rc_temp_ctiv  = 2,                                \
which setting can make the 32.768KHz RC works more accurate?
I think rc_ctiv=1, rc_temp_ctiv=1 can let the RC performs better, but with higher power consumption, am I right?
I want to figure this out, because my product sometimes disconnect with my BLE peripheral with an unexpected reason 0x3E(CONNECT_REQ is sent, but no reponse from slave, then connection timeout).
I found the issue can be induced by clock setting and the board RF performance, so I want to inquire if the rc_ctiv=1, rc_temp_ctiv=1 setting is the best setting for my board.
Thanks in advance.
  • Hi
    You can't guarantee better accuracy than 250ppm from the RC in the nRF51 series, but in general the more often you calibrate the more accurate it will be (at the cost of higher power consumption, as you say).
    The most aggressive settings you can use is rc_ctiv=1 and rx_temp_ctiv=0. Then the RC will be calibrated every 250ms, even if the temperature is stable.
    Best regards
    Torbjørn
  • Hello I am using custom nrf_ble_app_c central example on ISC-nrf52832-A which uses internal RC oscillator and I have done the configuration in sdk_config.h file for the RC oscillator selection
    // <h> Clock - SoftDevice clock configuration
    // <o> NRF_SDH_CLOCK_LF_SRC - SoftDevice clock source.
    // <0=> NRF_CLOCK_LF_SRC_RC
    // <1=> NRF_CLOCK_LF_SRC_XTAL
    // <2=> NRF_CLOCK_LF_SRC_SYNTH
    #ifndef NRF_SDH_CLOCK_LF_SRC
    #define NRF_SDH_CLOCK_LF_SRC 0
    // <o> NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval.
    #ifndef NRF_SDH_CLOCK_LF_RC_CTIV
    #define NRF_SDH_CLOCK_LF_RC_CTIV 1
    // <o> NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature.
    // <i> How often (in number of calibration intervals) the RC oscillator shall be calibrated
    // <i> if the temperature has not changed.
    #ifndef NRF_SDH_CLOCK_LF_RC_TEMP_CTIV
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 0
    // <o> NRF_SDH_CLOCK_LF_ACCURACY - External clock accuracy used in the LL to compute timing.
    // <0=> NRF_CLOCK_LF_ACCURACY_250_PPM
    // <1=> NRF_CLOCK_LF_ACCURACY_500_PPM
    // <2=> NRF_CLOCK_LF_ACCURACY_150_PPM
    // <3=> NRF_CLOCK_LF_ACCURACY_100_PPM
    // <4=> NRF_CLOCK_LF_ACCURACY_75_PPM
    // <5=> NRF_CLOCK_LF_ACCURACY_50_PPM
    // <6=> NRF_CLOCK_LF_ACCURACY_30_PPM
    // <7=> NRF_CLOCK_LF_ACCURACY_20_PPM
    // <8=> NRF_CLOCK_LF_ACCURACY_10_PPM
    // <9=> NRF_CLOCK_LF_ACCURACY_5_PPM
    // <10=> NRF_CLOCK_LF_ACCURACY_2_PPM
    // <11=> NRF_CLOCK_LF_ACCURACY_1_PPM
    #ifndef NRF_SDH_CLOCK_LF_ACCURACY
    #define NRF_SDH_CLOCK_LF_ACCURACY 1
    but the same is not working for me , please guide me
    Can you create a new ticket here, sharing info on your setup, what SDK version, hardware and so on, and you can link to this case for relevance.
    Jonathan
