NRF52, S132, peripheral dev ~180sec interval reboot on without connection
hello, I check the standard example
nRF5_SDK_14.2.0_17b948a\examples\ble_peripheral\ble_app_uart\pca10040\s132\arm5_no_packs
device nrf52DK PCA10040 V1.1.1
ARM Compiler : V5.06 update 4 build 422
When peripheral device is not connected to the app  it reboots every 180 sec
When device connected - its all right.
What parameter configures this reboots?
I want to disable this function. When BLE is off, there is no reboot.
when APP_ADV_TIMEOUT_IN_SECONDS 0,> 180 - reboot on configure
log:
test 1: ok
10:11:20.420 0.119 COM9 .UART Start!..
............ ..... .... 0a 55 41 52 54 20 53 74 61 72 74 21 0d 0a
// user message
10:12:21.368 60.948 COM9 he
............ ...... .... 68 65
10:12:21.479 0.111 COM9 llo world
............ ..... .... 6c 6c 6f 20 77 6f 72 6c 64
// manual nordic app disconnect
............ ..... .... 6f 6e 6e 65 63 74
10:53:29.892 2468.42 COM9 disconnect manual..
test 2: reset
10:56:07.545 157.653 COM9 .
............ ....... .... 0d
10:56:07.567 0.022 COM9 .UART Start!..
10:59:07.809 180.242 COM9 .
10:59:07.883 0.074 COM9 .UART Start!..
11:02:08.075 180.192 COM9 .
11:02:08.131 0.056 COM9 .UART Start!..
11:05:08.349 180.218 COM9 ..UART Start!..
............ ....... .... 0d 0a 55 41 52 54 20 53 74 61 72 74 21 0d 0a
11:08:08.610 180.261 COM9 .
11:08:08.641 0.031 COM9 .UART Start!..
test 2
load nRF5_SDK_14.2.0_17b948a\examples\ble_peripheral\ble_app_uart\hex\ble_app_uart_pca10040_s132.hex
313023 11:27:11.581 ----- COM9 UART Start!.
313024 11:30:11.827 180.246 COM9 .
313025 11:30:11.855 0.028 COM9 UART Start!.
313026 11:33:12.091 180.236 COM9 .
313027 11:33:12.103 0.012 COM9 UART Start!.
313028 11:36:12.356 180.253 COM9 .
313029 11:36:12.391 0.035 COM9 UART Start!.
best regards Oleksii
  • Hello! Are you sure that the device is not entering into the deep sleep? In this case, on GPIO event it reboots and starts from the beginning :) Check all functions that called like "power_manager, __WFE, __WFI and etc." :)
  • Hello Michael
    I think the problem is in configuring the SDK
    uart example nRF5_SDK_14.2.0_17b948a\examples\ble_peripheral\ble_app_uart\main.c`
    change
    #define APP_ADV_TIMEOUT_IN_SECONDS 30 /**< The advertising timeout (in units of seconds). */
    printf("reset UART Start!\r\n");
    err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    // Enter main loop.
    for (;;)
    // UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
    // power_manage();
    main problem - I can not disable this reboot
    log
    313056 13:12:41.488 30.261 COM9 reset UART Start!.
    313057 13:13:11.749 30.261 COM9 reset UART Start!.
    313058 13:13:42.010 30.261 COM9 reset UART Start!.
    313059 13:14:12.272 30.262 COM9 reset UART Start!.
    313060 13:14:42.533 30.261 COM9 reset UART Start!.
    313061 13:15:12.793 30.260 COM9 reset UART Start!.
    313062 13:15:43.057 30.264 COM9 reset UART Start!.
    313063 13:16:13.317 30.260 COM9 reset UART Start!.
    313064 13:16:43.578 30.261 COM9 reset UART Start!.
    313065 13:17:13.839 30.261 COM9 reset UART Start!.
    313066 13:17:44.101 30.262 COM9 reset UART Start!.
    313067 13:18:14.362 30.261 COM9 reset UART Start!.
  • Interesting... Let's see what one of the Nordic specialists will answer...
  • I get the error in function sleep_mode_enter(), that placed in on_adv_evt event handler. But restarting I don't see. Try to comment the function - let's see what we get.
  • static void on_adv_evt(ble_adv_evt_t ble_adv_evt)
    uint32_t err_code;
    switch (ble_adv_evt)
    case BLE_ADV_EVT_FAST:
    case BLE_ADV_EVT_IDLE:
    // sleep_mode_enter();
    the idea is partially true. no reboot now
    but the device is not scanned after 30 seconds by the application
    at #define APP_ADV_TIMEOUT_IN_SECONDS 30
    best regards, Oleksii
    uint32_t err_code;
    int err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    thank you
    code is correctly executed. no reboot
    on event  - I exe ble_advertising_start
    for understanding the problem of
    I need to better understand documentation. )
  • Great. But the problem is that the BLE device should be in sleep most of time, so we must understand why this error/restarts occurred Slight smile
    Let's wait for the Nordic specialist :)
