Hello Nordic Team,
i use SDK 12.3 and SoftDevice S130.
In the template project (\examples\ble_peripheral\ble_app_template ), the BSP module is used to indicate advertising and connection as described in the table of BSP indication states.
In the ble blinky example (\examples\ble_peripheral\experimental_ble_app_blinky), advertising and Connection is indicated using two different leds. I want the indication of advertising and connection to be in the same way as in the template project, but struggle with it. Based on the template project i made the following changes on the blinky example:
in on_ble_Event():
static void on_ble_evt(ble_evt_t * p_ble_evt)
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected\r\n");
//bsp_board_led_on(CONNECTED_LED_PIN); //changed here
//bsp_board_led_off(ADVERTISING_LED_PIN);
err_code = bsp_indiation_set(BSP_INDICATE_CONNECTED); //changed here
err_code = app_button_enable();
break; // BLE_GAP_EVT_CONNECTED
NRF_LOG_INFO("Disconnected\r\n");
//bsp_board_led_off(CONNECTED_LED_PIN); //changed here
err_code = bsp_indiation_set(BSP_INDICATE_IDLE); // changed here
err_code = app_button_disable();
advertising_start();
break; // BLE_GAP_EVT_DISCONNECTED
and in advertising_start():
err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING); //changed here
err_code = sd_ble_gap_adv_start(&adv_params);
//bsp_board_led_on(ADVERTISING_LED_PIN);
With this, advertising and connection still works but the states are not indicated via the leds. All leds are off. I think i need to initialise the bsp module somehow and tried different Settings with bsp_init but it didn't work.
So in short, my objective is:
- indicate advertising with a blinking led
- indicate Connection with the same lit led
- behaviour of the Buttons should stay the same. I do not want to use the BSP BLE Button Assignments (as far as i understand them)
- I am not fixed to the BSP module. A simple timer to blink the led would be sufficient, but somehow i couldn't realize it so far.
Kind regards and thanks in advance
