nRF51822 eval kit - Error: Device Support not found
I just got the nrf51822 evaluation kit. I followed the instruction and installed everything per instruction. When I tried to open “Blinky” project, I am getting the following error:
“ Error: Device Support not found Device: nRF51822_xxAA
The device support might be part of ….
“ There are several packages and I have installed the first one for CortexM0 and I am still getting the error. Any idea?
  • Have the same problem, it appears the devices listed separately are all there, but the ones that require a + expansion box to be clicked do not show up. I have tried installing the legacy support, then uninstalled NRF 51 SDK and reinstalled it. The Generic Database does not show up at all. All the 8051 based products from Nordic show up in the selection list, but none of the ARM based. Can't seem to nail this - and the description is exactly as Scott's .
    UPDATE: It appears that the correct target can be selected from the menu "Set target for project", whereas the target tab in the project options does not work. The project options will only display 8051 based processors, whereas the "Select target" shows the ARM options. Then that seems to work. The NRF SDK51 path however creates huge trouble. There used to be no spaces in the "c:\Nordic_Semiconductor\NRF_SDK51 path, but now the path has spaces instead of underscores. This kills the compiler, which looks for a partial string in the file names. It can't find several files, even if I put in the complete path in the project manager and can open them by double clicking.
    K
    K
