Central Multilink: how to add custom characteristic uuid?
I'm using Central multilink example to connect with our Custom Peripheral sensors.
I'm using board PCA10040, nRF52832, SDK_14.2.0, s132.
Sensors have a custom service (UUID 128 bit) with 4 custom characteristics (UUID 128 bit) and I know all these UUID of service and characteristics.
From the Central multilink example I used the function "ble_lbs_c_init" where I modified it to set our SERVICE_UUIDBASE of the custom service of the sensor.
In this case, Do I need to add something else regarding the 4 custom characteristics?
uint32_t ble_lbs_c_init(ble_lbs_c_t * p_ble_lbs_c, ble_lbs_c_init_t * p_ble_lbs_c_init)
    uint32_t      err_code;
    ble_uuid_t    lbs_uuid;
    ble_uuid128_t lbs_base_uuid = {LBS_UUID_BASE};
    VERIFY_PARAM_NOT_NULL(p_ble_lbs_c);
    VERIFY_PARAM_NOT_NULL(p_ble_lbs_c_init);
    VERIFY_PARAM_NOT_NULL(p_ble_lbs_c_init->evt_handler);
    p_ble_lbs_c->peer_lbs_db.button_cccd_handle = BLE_GATT_HANDLE_INVALID;
    p_ble_lbs_c->peer_lbs_db.button_handle      = BLE_GATT_HANDLE_INVALID;
    p_ble_lbs_c->peer_lbs_db.led_handle         = BLE_GATT_HANDLE_INVALID;
    p_ble_lbs_c->conn_handle                    = BLE_CONN_HANDLE_INVALID;
    p_ble_lbs_c->evt_handler                    = p_ble_lbs_c_init->evt_handler;
    err_code = sd_ble_uuid_vs_add(&lbs_base_uuid, &p_ble_lbs_c->uuid_type);
    if (err_code != NRF_SUCCESS)
        return err_code;
    VERIFY_SUCCESS(err_code);
    lbs_uuid.type = p_ble_lbs_c->uuid_type;
    lbs_uuid.uuid = LBS_UUID_SERVICE;
    return ble_db_discovery_evt_register(&lbs_uuid);
Because I'm able to connect with sensors but when I receive the event BLE_DB_DISCOVERY_COMPLETE (function ble_lbs_on_db_disc_evt), I don't read the uuid of the 4 custom characteristics but I read characteristic.uuid.uuid = 0x00.
Please could someone help me please?
  • Hi Ketil,
    I sent by private message the custom service at 128 bits of the sensor.
    Please could you tell me if I set in correct way the define
    #define LBS_UUID_BASE
    #define LBS_UUID_SERVICE
    Thank you in advance
  • Hi all,
    Please could someone help me?
    I'm working side "multilink central" and I already have a working sensor to connect with.
    I need to discover the custom sensor profile but I only get characteristic.uuid.uuid = 0x00 and characteristic.uuid.type = 0x00  when I receive the event BLE_DB_DISCOVERY_COMPLETE. This is probably because I didn't set the configuration properly  of the 4 UUIDs at 128bits of characteristics.
    The custom sensor profile consist of 1 custom service at128bits and "4 custom characteristics at 128bits". Each characteristic has different uuid at 128bits even from custom service uuid at 128bit.
    Do I need to use the sd_ble_uuid_vs_add to add the 4 UUIDs at 128bits characteristics? If yes, how should I do it?
    Thank you in advance.
  • Hi Gandalf,
    Sorry for the late reply. We are in the middle of a holiday and answers might be slow.
    Yes, you should use the sd_ble_uuid_vs_add() function for all your vendor specific UUIDs, including characteristics. Note that you will have to tell the SoftDevice to reserve memory for these additional UUIDs with vs_uuid_count. Please take a look at this post for example code.
    Ketil
  • Hi Ketil,
    thank you for the information.
    Don't worry, me too for the holiday Slight smile
    I solved by using sd_ble_uuid_vs_add() for all vendor specific UUIDs and characteristics and I incremented the memory of the SoftDevice.
    Thank you!!
