I'm using Central multilink example to connect with our Custom Peripheral sensors.
I'm using board PCA10040, nRF52832, SDK_14.2.0, s132.
Sensors have a custom service (UUID 128 bit) with 4 custom characteristics (UUID 128 bit) and I know all these UUID of service and characteristics.
From the Central multilink example I used the function "ble_lbs_c_init" where I modified it to set our SERVICE_UUIDBASE of the custom service of the sensor.
In this case, Do I need to add something else regarding the 4 custom characteristics?
uint32_t ble_lbs_c_init(ble_lbs_c_t * p_ble_lbs_c, ble_lbs_c_init_t * p_ble_lbs_c_init) { uint32_t err_code; ble_uuid_t lbs_uuid; ble_uuid128_t lbs_base_uuid = {LBS_UUID_BASE}; VERIFY_PARAM_NOT_NULL(p_ble_lbs_c); VERIFY_PARAM_NOT_NULL(p_ble_lbs_c_init); VERIFY_PARAM_NOT_NULL(p_ble_lbs_c_init->evt_handler); p_ble_lbs_c->peer_lbs_db.button_cccd_handle = BLE_GATT_HANDLE_INVALID; p_ble_lbs_c->peer_lbs_db.button_handle = BLE_GATT_HANDLE_INVALID; p_ble_lbs_c->peer_lbs_db.led_handle = BLE_GATT_HANDLE_INVALID; p_ble_lbs_c->conn_handle = BLE_CONN_HANDLE_INVALID; p_ble_lbs_c->evt_handler = p_ble_lbs_c_init->evt_handler; err_code = sd_ble_uuid_vs_add(&lbs_base_uuid, &p_ble_lbs_c->uuid_type); if (err_code != NRF_SUCCESS) { return err_code; } VERIFY_SUCCESS(err_code); lbs_uuid.type = p_ble_lbs_c->uuid_type; lbs_uuid.uuid = LBS_UUID_SERVICE; return ble_db_discovery_evt_register(&lbs_uuid); }
Because I'm able to connect with sensors but when I receive the event BLE_DB_DISCOVERY_COMPLETE (function ble_lbs_on_db_disc_evt), I don't read the uuid of the 4 custom characteristics but I read characteristic.uuid.uuid = 0x00.
Please could someone help me please?
