802.15.4 problem with encryption and promiscuous mode
I have a problem with the 802.15.4 software part of my nRF52840 PDK.
I wanted to replace our current 802.15.4 hardware parts from TI with the new nRF52840, due to the lack of support and missing gcc compatibility.
Therefore I tried to implement a working 802.15.4 application, based on the wireless uart example in the sdk directory.
So I enabled the promiscuous mode on the device, to capture all the packages which were sent wireless. I also receive the packages which were sent, but since they are encrypted, I can't see the content. But I also don't receive the right src_addr and dst_addr, I get always MAC_ADDR_NONE back.
If I run the following program on the device,
#ifdef __cplusplus
extern "C" {
#include "802_15_4_config.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "ral_irq_handlers.h"
#include "nrf_drv_clock.h"
#include "boards.h"
#include "mac_mcps_data.h"
#include "sys_init.h"
#include "sys_task_scheduler.h"
#include "mac_common.h"
#include "mac_mlme_beacon_notify.h"
#include "mac_mlme_comm_status.h"
#include "mac_mlme_pib.h"
#include "mac_mlme_scan.h"
#include "mac_security.h"
#ifdef __cplusplus
#include "SEGGER_RTT.h"
#include "SEGGER_RTT_Conf.h"
#define CONFIG_POOL_SIZE 0x2000
static __ALIGN(ALIGN_VALUE) uint8_t m_heap[CONFIG_POOL_SIZE];
#define CONFIG_ERROR_PIN LED_4
#define C11 (1 << 11)
#define C12 (1 << 12)
#define C13 (1 << 13)
#define C14 (1 << 14)
#define C15 (1 << 15)
#define C16 (1 << 16)
#define C17 (1 << 17)
#define C18 (1 << 18)
#define C19 (1 << 19)
#define C20 (1 << 20)
#define C21 (1 << 21)
#define C22 (1 << 22)
#define C23 (1 << 23)
#define C24 (1 << 24)
#define C25 (1 << 25)
#define C26 (1 << 26)
static void out_of_memory_callback(const void* data);
static void memory_freed_callback(const void* data);
#ifdef __cplusplus
constexpr sys_event_desc_t gen_sys_event_desc_t(sys_event_id_t event_id,
                                                void(callback)(const void*)) {
    return sys_event_desc_t{sys_queue_item_t{}, event_id, callback};
static sys_event_desc_t m_out_of_memory_desc =
    gen_sys_event_desc_t(SYS_EVENT_OUT_OF_MEMORY, out_of_memory_callback);
static sys_event_desc_t m_memory_freed_desc =
    gen_sys_event_desc_t(SYS_EVENT_MEMORY_FREED, memory_freed_callback);
#else
static sys_event_desc_t m_out_of_memory_desc = {
    .event_id = SYS_EVENT_OUT_OF_MEMORY, .callback = out_of_memory_callback};
static sys_event_desc_t m_memory_freed_desc = {
    .event_id = SYS_EVENT_MEMORY_FREED, .callback = memory_freed_callback};
static void out_of_memory_callback(const void* data) {
    LEDS_ON(BIT(CONFIG_ERROR_PIN));
static void memory_freed_callback(const void* data) {
    LEDS_OFF(BIT(CONFIG_ERROR_PIN));
static void app_task_init(void) {
    LEDS_CONFIGURE(LEDS_MASK);
    LEDS_OFF(LEDS_MASK);
    sys_init(m_heap, CONFIG_POOL_SIZE);
    sys_event_subscribe(&m_out_of_memory_desc);
    sys_event_subscribe(&m_memory_freed_desc);
static void clock_init(void) {
    ret_code_t err_code = nrf_drv_clock_init();
    ASSERT((err_code == NRF_SUCCESS) ||
           (err_code == NRF_ERROR_MODULE_ALREADY_INITIALIZED));
    nrf_drv_clock_hfclk_request(NULL);
    while (!nrf_drv_clock_hfclk_is_running()) {
        // spin lock
    while (!nrf_drv_clock_lfclk_is_running()) {
        // spin lock
void print_mac_status(const mac_status_t status) {
    switch (status) {
        case MAC_NO_BEACON:
            SEGGER_RTT_printf(0, "MAC_NO_BEACON");
        case MAC_SUCCESS:
            SEGGER_RTT_printf(0, "MAC_SUCCESS");
        case MAC_LIMIT_REACHED:
            SEGGER_RTT_printf(0, "MAC_LIMIT_REACHED");
            SEGGER_RTT_printf(0, "0x%x", status);
void print_addr(const mac_addr_t* addr, const mac_addr_mode_t addr_mode,
                const char* field) {
    SEGGER_RTT_printf(0, "%s: ", field);
    switch (addr_mode) {
        case MAC_ADDR_NONE:
            SEGGER_RTT_printf(0, "NONE");
        case MAC_ADDR_SHORT:
            SEGGER_RTT_printf(0, "0x%04x (short)", addr->short_address);
        case MAC_ADDR_LONG:
            SEGGER_RTT_printf(0, "0x%08x%08x (long)",
                              (uint32_t)(addr->long_address >> 32),
                              (uint32_t)(addr->long_address));
void print_pan_desc(const mac_pan_descriptor_t* pan) {
    SEGGER_RTT_printf(0, "{coord_pan_id: 0x%04x, ", pan->coord_pan_id);
    print_addr(&(pan->coord_address), pan->coord_addr_mode, "address");
                      ", logical_channel: %u, timestamp: 0x%x, link_quality: "
                      "%u, superframe_spec: 0x%x, gts: %s}",
                      pan->logical_channel, pan->timestamp, pan->link_quality,
                      pan->superframe_spec, pan->gts_permit ? "true" : "false");
void print_scan_conf(const mlme_scan_conf_t* sc) {
    SEGGER_RTT_printf(0, "{status: ");
    print_mac_status(sc->status);
    SEGGER_RTT_printf(0, ", scan_type: ");
    switch (sc->scan_type) {
        case ED_SCAN:
            SEGGER_RTT_printf(0, "ED_SCAN");
        case ACTIVE_SCAN:
            SEGGER_RTT_printf(0, "ACTIVE_SCAN");
        case PASSIVE_SCAN:
            SEGGER_RTT_printf(0, "PASSIVE_SCAN");
        case ORPHAN_SCAN:
            SEGGER_RTT_printf(0, "ORPHAN_SCAN");
            SEGGER_RTT_printf(0, "Unknown(%x)", sc->scan_type);
    SEGGER_RTT_printf(0, ", unscanned_channels: %x", sc->unscanned_channels);
    SEGGER_RTT_printf(0, ", result_list_size: %u, results: {",
                      sc->result_list_size);
    for (size_t i = 0; i < sc->result_list_size; i++) {
        const mac_pan_descriptor_t* pan = &(sc->pan_descriptor_list[i]);
        const uint8_t energy = sc->energy_detect_list[i];
        SEGGER_RTT_printf(0, "Result %u: {energy: %x, pan_descriptor: ", i,
                          energy);
        print_pan_desc(pan);
        SEGGER_RTT_printf(0, "}, ");
    SEGGER_RTT_printf(0, "}\n");
void print_beacon_notify_ind(const mlme_beacon_notify_ind_t* ind) {
    SEGGER_RTT_printf(0, "{bsn: %u, pan_descriptor: ", ind->bsn);
    print_pan_desc(&(ind->pan_descriptor));
    SEGGER_RTT_printf(0, ", sdu_length: %u, sdu: 0x", ind->sdu_length);
    for (size_t i = 0u; i < ind->sdu_length; i++) {
        SEGGER_RTT_printf(0, "%02x", ind->sdu.p_payload[i]);
    SEGGER_RTT_printf(0, ", pend_addr_spec: %x}\n", ind->pend_addr_spec);
void print_data_ind(const mcps_data_ind_t* ind) {
    SEGGER_RTT_printf(0, "{src_pan_id: 0x%04x, ", ind->src_pan_id);
    print_addr(&(ind->src_addr), ind->src_addr_mode, "src_addr");
    SEGGER_RTT_printf(0, ", dst_pan_id: 0x%04x, ", ind->dst_pan_id);
    print_addr(&(ind->dst_addr), ind->dst_addr_mode, "dst_addr");
    SEGGER_RTT_printf(0, ", msdu_length: %u, sdu: 0x", ind->msdu_length);
    for (size_t i = 0u; i < ind->msdu_length; i++) {
        SEGGER_RTT_printf(0, "%02x", ind->msdu.p_payload[i]);
    SEGGER_RTT_printf(0, ", mpdu_link_quality: %u", ind->mpdu_link_quality);
    SEGGER_RTT_printf(0, ", dsn: %u", ind->dsn);
    SEGGER_RTT_printf(0, ", timestamp: %u}\n", ind->timestamp);
    SEGGER_RTT_printf(0, "\n");
void mlme_beacon_notify_ind(mlme_beacon_notify_ind_t* _ind) {
    SEGGER_RTT_printf(0, "Received Beacon: ");
    print_beacon_notify_ind(_ind);
void mcps_data_ind(mcps_data_ind_t* _ind) {
    SEGGER_RTT_printf(0, "Received Data: \n");
    print_data_ind(_ind);
pib_id_t gen_pib_id_t_plme(plme_pib_attr_id_t id) {
    pib_id_t ret;
    ret.plme_id = id;
    return ret;
pib_id_t gen_pib_id_t(mlme_pib_attr_id_t id) {
    pib_id_t ret;
    ret.mlme_id = id;
    return ret;
void print_pib_get_request(const uint8_t* value, uint16_t size,
                           const char* name) {
    SEGGER_RTT_printf(0, "mlme_get: %s: 0x", name);
    for (uint16_t i = 0; i < size; i++) {
        SEGGER_RTT_printf(0, "%02x", value[i]);
const uint8_t* pib_get_request(pib_id_t id, const char* name) {
    static uint8_t value[256];
    mac_status_t res = mlme_get(id, 0, value);
    if (res != MAC_SUCCESS) {
        SEGGER_RTT_printf(0, "failure in pib-get request: ");
        print_mac_status(res);
        // TODO: handle this error
        return NULL;
    print_pib_get_request(value, mlme_pib_attr_size_calc(id, 0), name);
    return value;
void gen_mac_key_descr_t(mac_key_descr_t* key_descr) {
    mac_table_init(&key_descr->id_lookup_list);
    mac_table_init(&key_descr->key_device_list);
    mac_table_init(&key_descr->key_usage_list);
mac_device_descr_t gen_mac_device_descr_t(uint16_t pan_id,
                                          uint16_t short_address,
                                          uint64_t extended_address,
                                          uint32_t frame_counter, bool exempt) {
    mac_device_descr_t ret;
    ret.pan_id = pan_id;
    ret.short_address = short_address;
    ret.extended_address = extended_address;
    ret.frame_counter = frame_counter;
    ret.exempt = exempt;
    return ret;
mac_security_level_descr_t gen_mac_security_level_descr_t(
    uint8_t frame_type, uint8_t cmd_frame_id, uint8_t security_min,
    uint8_t override_min) {
    mac_security_level_descr_t ret;
    ret.security_min = security_min;
    ret.override_min = override_min;
    ret.frame_type = frame_type;
    ret.cmd_frame_id = cmd_frame_id;
    return ret;
mac_key_id_lookup_descr_t gen_mac_key_id_lookup_descr_t(
    mac_key_lookup_size_t size) {
    mac_key_id_lookup_descr_t ret;
    ret.size = size;
    return ret;
mac_key_device_descr_t gen_mac_key_device_descr_t(uint8_t device_handle,
                                                  uint8_t unique_device,
                                                  uint8_t blacklisted) {
    mac_key_device_descr_t ret;
    ret.device_handle = device_handle;
    ret.blacklisted = blacklisted;
    ret.unique_device = unique_device;
    return ret;
mac_key_usage_descr_t gen_mac_key_usage_descr_t(uint8_t frame_type,
                                                uint8_t cmd_frame_id) {
    mac_key_usage_descr_t ret;
    return ret;
bool callback_called = false;
void scan_callback(mlme_scan_conf_t* sc) { callback_called = true; };
mlme_scan_req_t gen_mac_scan_req_t(
    mac_scan_type_t scan_type, uint32_t scan_channels, uint8_t scan_duration,
    mac_pan_descriptor_t* pan_desc_buf, size_t pan_desc_size,
    uint8_t* energy_detect_buf, size_t energy_detect_size) {
    mlme_scan_req_t ret;
    ret.scan_type = scan_type;
    ret.scan_channels = scan_channels;
    ret.scan_duration = scan_duration;
    ret.pan_descriptors_buf = pan_desc_buf;
    ret.pan_descriptors_buf_size = pan_desc_size;
    ret.energy_detect_buf = energy_detect_buf;
    ret.energy_detect_buf_size = energy_detect_size;
    return ret;
const mlme_scan_conf_t* scan_req(mac_scan_type_t scan_type,
                                 uint8_t scan_duration) {
#define _ENERGY_DET_SIZE 8
#define _PAN_DESC_SIZE 8
    static mac_pan_descriptor_t pd[_PAN_DESC_SIZE];
    static uint8_t ed[_ENERGY_DET_SIZE];
    static mlme_scan_req_t scan_req;
    scan_req = gen_mac_scan_req_t(scan_type, scan_channels, scan_duration, pd,
                                  _PAN_DESC_SIZE, ed, _ENERGY_DET_SIZE);
    mlme_scan_req(&scan_req, scan_callback);
    while (!callback_called) {
        sys_task_run();
    return &scan_req.confirm;
void dummy_wait() {
    SEGGER_RTT_printf(0, "dummy wait: ...");
    for(volatile size_t i=0; i<1024*1024*8; i++) {
        uint32_t j = (i + 10 )%(1024*1024*2);
        if(j+44 == 88) {
            SEGGER_RTT_printf(0, "%d,", j);
int main(void) {
    ral_irq_handler_import();
    SEGGER_RTT_Init();
    uint8_t rtt_buf_out[1024u];
    SEGGER_RTT_ConfigUpBuffer(0, "OUT", rtt_buf_out, 1024u,
                              SEGGER_RTT_MODE_NO_BLOCK_TRIM);
    app_task_init();
    sys_task_post(APP_TASK_ID);
    clock_init();
    SEGGER_RTT_printf(0, "....RESET....\n");
#if (CONFIG_SECURE == 1)
    SEGGER_RTT_printf(0, "Compiled with CONFIG_SECURE\n");
    static uint8_t security_enabled = true;
    static uint16_t pan_id = 0x11CCU;
    static uint16_t other_address = 0xFFFEU;
    static uint64_t pan_external = 0x1122334455667788ULL;
    static uint8_t promiscuous_mode = true;
    static uint8_t rx_on_when_idle = true;
    static uint8_t channel_id = 14u;
    static uint8_t key[MAC_SECURITY_KEY_SIZE] = {
        0x12u, 0x34u, 0x56u, 0x78u, 0x9Au, 0xBCu, 0xDEu, 0xF0u,
        0x00u, 0x00u, 0x00u, 0x00u, 0x00u, 0x00u, 0x00u, 0x00u};
    static const uint8_t key_lookup_data[KEY_LOOKUP_SIZE_NINE_VAL] = {
        0x33, 0x33, 0x33, 0x33, 0x33, 0x33, 0x33, 0x33, 0x03};
    static uint8_t default_source[KEY_LOOKUP_SIZE_NINE_VAL - 1] = {
        0x33, 0x33, 0x33, 0x33, 0x33, 0x33, 0x33, 0x33};
    static uint8_t auto_request_security_level = MAC_SEC_OFF;
    static mac_security_level_descr_t sec_level_descr;
    sec_level_descr = gen_mac_security_level_descr_t(MAC_DATA, MAC_CMD_DATA_REQ,
                                                     MAC_SEC_OFF, false);
    static mac_key_id_lookup_descr_t key_id_lookup_descr;
    key_id_lookup_descr = gen_mac_key_id_lookup_descr_t(KEY_LOOKUP_SIZE_NINE);
    memcpy(key_id_lookup_descr.data, key_lookup_data, KEY_LOOKUP_SIZE_NINE_VAL);
    static mac_key_device_descr_t key_device_descr;
    key_device_descr = gen_mac_key_device_descr_t(0, false, false);
    key_device_descr.table_service.idx = 0;
    static mac_device_descr_t device_descr;
    device_descr =
        gen_mac_device_descr_t(pan_id, other_address, pan_external, 0, false);
    static mac_key_usage_descr_t key_usage_descr;
    key_usage_descr = gen_mac_key_usage_descr_t(MAC_DATA, MAC_CMD_DATA_REQ);
    // build the key_descr-table:
    static mac_key_descr_t key_descr;
    gen_mac_key_descr_t(&key_descr);
    mac_status_t ret1 = mac_table_item_set(&key_descr.id_lookup_list,
                                           &key_id_lookup_descr.table_service,
                                           MAC_KEY_ID_LOOKUP_LIST, 0);
    SEGGER_RTT_printf(0, "table item set1: ");
    print_mac_status(ret1);
    mac_status_t ret2 = mac_table_item_set(&key_descr.key_device_list,
                                           &key_device_descr.table_service,
                                           MAC_KEY_DEVICE_LIST, 0);
    SEGGER_RTT_printf(0, "\ntable item set2: ");
    print_mac_status(ret2);
    mac_status_t ret3 = mac_table_item_set(&key_descr.key_usage_list,
                                           &key_usage_descr.table_service,
                                           MAC_KEY_USAGE_LIST, 0);
    SEGGER_RTT_printf(0, "\ntable item set3: ");
    print_mac_status(ret3);
    memcpy(key_descr.key, key, MAC_SECURITY_KEY_SIZE);
        SEGGER_RTT_printf(0, "starting the scan\n");
        print_scan_conf(scan_req(ACTIVE_SCAN, C14, 7));
        SEGGER_RTT_printf(0, "finished the scan\n");
        mac_status_t state = mlme_set(gen_pib_id_t(MAC_PAN_ID), 0, &pan_id);
        if (state != MAC_SUCCESS) {
            SEGGER_RTT_printf(0, "failure in pib-set request: ");
            print_mac_status(state);
        pib_get_request(gen_pib_id_t(MAC_PAN_ID), "MAC_PAN_ID");
            gen_pib_id_t(MAC_PAN_COORD_EXTENDED_ADDRESS), 0, &pan_external);
        pib_get_request(gen_pib_id_t(MAC_PAN_COORD_EXTENDED_ADDRESS),
                        "MAC_PAN_COORD_EXTENDED_ADDRESS");
            mlme_set(gen_pib_id_t(MAC_PROMISCUOUS_MODE), 0, &promiscuous_mode);
        pib_get_request(gen_pib_id_t(MAC_PROMISCUOUS_MODE),
                        "MAC_PROMISCOUS_MODE");
    dummy_wait();
            mlme_set(gen_pib_id_t(MAC_RX_ON_WHEN_IDLE), 0, &rx_on_when_idle);
        pib_get_request(gen_pib_id_t(MAC_RX_ON_WHEN_IDLE),
                        "MAC_RX_ON_WHEN_IDLE");
            mlme_set(gen_pib_id_t_plme(PHY_CURRENT_CHANNEL_ID), 0, &channel_id);
        pib_get_request(gen_pib_id_t_plme(PHY_CURRENT_CHANNEL_ID),
                        "PHY_CURRENT_CHANNEL_ID");
            mlme_set(gen_pib_id_t(MAC_KEY_TABLE), 0, &key_descr);
        pib_get_request(gen_pib_id_t(MAC_KEY_TABLE), "MAC_KEY_TABLE");
        pib_get_request(gen_pib_id_t(MAC_KEY_TABLE_ENTRIES),
                        "MAC_KEY_TABLE_ENTRIES");
            mlme_set(gen_pib_id_t(MAC_DEVICE_TABLE), 0, &device_descr);
        pib_get_request(gen_pib_id_t(MAC_DEVICE_TABLE), "MAC_DEVICE_TABLE");
        pib_get_request(gen_pib_id_t(MAC_DEVICE_TABLE_ENTRIES),
                        "MAC_DEVICE_TABLE_ENTRIES");
        mac_status_t state = mlme_set(gen_pib_id_t(MAC_SECURITY_LEVEL_TABLE), 0,
                                      &sec_level_descr);
        pib_get_request(gen_pib_id_t(MAC_SECURITY_LEVEL_TABLE),
                        "MAC_SECURITY_LEVEL_TABLE");
        pib_get_request(gen_pib_id_t(MAC_SECURITY_LEVEL_TABLE_ENTRIES),
                        "MAC_SECURITY_LEVEL_TABLE_ENTRIES");
    dummy_wait();
            mlme_set(gen_pib_id_t(MAC_DEFAULT_KEY_SOURCE), 0, &default_source);
        pib_get_request(gen_pib_id_t(MAC_DEFAULT_KEY_SOURCE),
                        "MAC_DEFAULT_KEY_SOURCE");
            mlme_set(gen_pib_id_t(MAC_AUTO_REQUEST_SECURITY_LEVEL), 0,
                     &auto_request_security_level);
        //pib_get_request(gen_pib_id_t(MAC_AUTO_REQUEST_SECURITY_LEVEL),
        //                "MAC_AUTO_REQUEST_SECURITY_LEVEL");
            mlme_set(gen_pib_id_t(MAC_SECURITY_ENABLED), 0, &security_enabled);
        pib_get_request(gen_pib_id_t(MAC_SECURITY_ENABLED),
                        "MAC_SECURITY_ENABLED");
    while (true) {
        sys_task_run();
I get the following results from SEGGER-RTT:
....RESET....
table item set1: MAC_SUCCESS
table item set2: MAC_SUCCESS
table item set3: MAC_SUCCESS
starting the scan
Received Beacon: {bsn: 113, pan_descriptor: {coord_pan_id: 0x11CC, address: 0x8877665544332211 (long), logical_channel: 14, timestamp: 0x2081, link_quality: 63, superframe_spec: 0xCFFF, gts: false}, sdu_length: 16, sdu: 0x123456789ABCDEF00000000000000000, pend_addr_spec: 0}
{status: MAC_SUCCESS, scan_type: ACTIVE_SCAN, unscanned_channels: 0, result_list_size: 1, results: {Result 0: {energy: 0, pan_descriptor: {coord_pan_id: 0x11CC, address: 0x8877665544332211 (long), logical_channel: 14, timestamp: 0x2081, link_quality: 63, superframe_spec: 0xCFFF, gts: false}}, }
finished the scan
mlme_get: MAC_PAN_ID: 0xCC11
mlme_get: MAC_PAN_COORD_EXTENDED_ADDRESS: 0x8877665544332211
mlme_get: MAC_PROMISCOUS_MODE: 0x01
dummy wait: ...44,44,44,44,
mlme_get: MAC_RX_ON_WHEN_IDLE: 0x01
mlme_get: PHY_CURRENT_CHANNEL_ID: 0x0E
mlme_get: MAC_KEY_TABLE: 0xA82300204433221100000000000000000000000000000000000000000000000000000000000000000000000000000000
mlme_get: MAC_KEY_TABLE_ENTRIES: 0x01
mlme_get: MAC_DEVICE_TABLE: 0x7823002044332211000000000000000000000000000000000000000000000000
mlme_get: MAC_DEVICE_TABLE_ENTRIES: 0x01
mlme_get: MAC_SECURITY_LEVEL_TABLE: 0x5C2300204433221100000000
mlme_get: MAC_SECURITY_LEVEL_TABLE_ENTRIES: 0x01
mlme_get: MAC_DEFAULT_KEY_SOURCE: 0x3333333333333333
mlme_get: MAC_SECURITY_ENABLED: 0x01
Received Data:
{src_pan_id: 0x11CC, src_addr: NONE, dst_pan_id: 0xFFFF, dst_addr: NONE, msdu_length: 47, sdu: 0x69DC57CC111122334455667788A0B0C0D0E0F000740D02000000039EB12FC9D262D0ED918997962EE3D0C3B2B4E7B7, mpdu_link_quality: 67, dsn: 113, timestamp: 755227328}
Received Data:
{src_pan_id: 0x11CC, src_addr: NONE, dst_pan_id: 0xFFFF, dst_addr: NONE, msdu_length: 3, sdu: 0x020057, mpdu_link_quality: 63, dsn: 113, timestamp: 755227872}
So I don't know, what I initialized wrong, because as you can see in the output, the payload is not encrypted and the source and dest addresses are not correct.
To compile the attatched file, you can simply copy it as main.c in the wireless uart example (dir: /nRF5_SDK_14.2.0_17b948a/examples/802_15_4/experimental/wireless_uart)
I use the SDK 14.2.0 with armgcc 7.2.
    Here is the information you asked for. I hope you find it helpful.
    Source and destination addresses cannot be populated (set to 0x00) when operating in promiscuous mode. According to the 802.15.4-2006 specification:
    "When in promiscuous mode, the MAC sublayer shall process received frames according to 7.5.6.2 and pass
    all frames correctly received to the next higher layer using the MCPS-DATA.indication primitive. The
    source and destination addressing mode parameters shall each be set to 0x00, the MSDU parameter shall
    contain the MHR concatenated with the MAC payload (see Figure 41), and the msduLength parameter shall
    contain the total number of octets in the MHR concatenated with the MAC payload. The mpduLinkQuality
    shall be valid."
    And another fragment from the specification:
    "In promiscuous mode, the MAC sublayer shall pass all frames received after the first
    filter directly to the upper layers without applying any more filtering or processing."
    FYI, the first filter just checks if CRC (FCS field, present in MAC frame) is correct. That's why, in the promiscuous mode, you get raw messages without any field parsing. In this case you can ignore most of the fields that you receive in the indication (exceptions: msdu, link_quality, timestamp).
    Since there is little interpretation of incoming frame in promiscuous mode at MAC layer level, the msdu payload is not decrypted by the stack.
