how to use GPIO port 1 for Uarts
Hey..
I'm having difficulties using P1 pins for UARTE0 and/or UARTE1.
configuring the RX & TX pins like this works great:
#define RBP_UARTE0_RX_PIN_NUMBER NRF_GPIO_PIN_MAP(0,26)
#define RBP_UARTE0_TX_PIN_NUMBER NRF_GPIO_PIN_MAP(0,27)
#define RBP_UARTE1_RX_PIN_NUMBER NRF_GPIO_PIN_MAP(0,8)
#define RBP_UARTE1_TX_PIN_NUMBER NRF_GPIO_PIN_MAP(0,6)
But if I change UARTE1 (and move the wires, obviously) to the following, I see nothing on UARTE1
#define RBP_UARTE1_RX_PIN_NUMBER NRF_GPIO_PIN_MAP(1,8)
#define RBP_UARTE1_TX_PIN_NUMBER NRF_GPIO_PIN_MAP(1,6)
I have, in fact, not had any luck with any of the P1 pins I've tried. Is there something I'm missing that needs doing before I can use P1?
see attached program & sdk_config.h
/*$$$LICENCE_NORDIC_STANDARD<2016>$$$*/
#include <stdint.h>
#include <stdbool.h>
#include <stddef.h>
#include <stdio.h>
#include "nrf.h"
#include "nrf_drv_clock.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_power.h"
#include "nrf_drv_uart.h"
#include "nrf_serial.h"
#include "app_timer.h"
#include "app_error.h"
#include "app_util.h"
#include "boards.h"
/** @file
 * @defgroup nrf_serial_example main.c
 * @ingroup nrf_serial_example
 * @brief Example of @ref nrf_serial usage. Simple loopback.
#define OP_QUEUES_SIZE          3
#define APP_TIMER_PRESCALER     NRF_SERIAL_APP_TIMER_PRESCALER
static void sleep_handler(void)
    __WFE();
    __SEV();
    __WFE();
#define RBP_UARTE0_CTS_PIN_NUMBER NRF_UART_PSEL_DISCONNECTED
#define RBP_UARTE0_RTS_PIN_NUMBER NRF_UART_PSEL_DISCONNECTED
#define RBP_UARTE0_HWFC           false
#define RBP_UARTE1_CTS_PIN_NUMBER NRF_UART_PSEL_DISCONNECTED
#define RBP_UARTE1_RTS_PIN_NUMBER NRF_UART_PSEL_DISCONNECTED
#define RBP_UARTE1_HWFC           false
NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uart0_drv_config,
                      RBP_UARTE0_RX_PIN_NUMBER,
                      RBP_UARTE0_TX_PIN_NUMBER,
                      RBP_UARTE0_RTS_PIN_NUMBER,
                      RBP_UARTE0_CTS_PIN_NUMBER,
                      RBP_UARTE0_HWFC,
                      NRF_UART_PARITY_EXCLUDED,
                      NRF_UART_BAUDRATE_115200,
                      UART_DEFAULT_CONFIG_IRQ_PRIORITY);
NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uart1_drv_config,
                      RBP_UARTE1_RX_PIN_NUMBER,
                      RBP_UARTE1_TX_PIN_NUMBER,
                      RBP_UARTE1_RTS_PIN_NUMBER,
                      RBP_UARTE1_CTS_PIN_NUMBER,
                      RBP_UARTE1_HWFC,
#define TEST_UARTE0
#define TEST_UARTE1
#define SERIAL_FIFO_TX_SIZE 128
#define SERIAL_FIFO_RX_SIZE 128
NRF_SERIAL_QUEUES_DEF(serial0_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
NRF_SERIAL_QUEUES_DEF(serial1_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
#define SERIAL_BUFF_TX_SIZE 1
#define SERIAL_BUFF_RX_SIZE 1
NRF_SERIAL_BUFFERS_DEF(serial0_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
NRF_SERIAL_BUFFERS_DEF(serial1_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
NRF_SERIAL_CONFIG_DEF(serial0_config, NRF_SERIAL_MODE_IRQ,
                      &serial0_queues, &serial0_buffs, NULL, sleep_handler);
NRF_SERIAL_CONFIG_DEF(serial1_config, NRF_SERIAL_MODE_IRQ,
                      &serial1_queues, &serial1_buffs, NULL, sleep_handler);
NRF_SERIAL_UART_DEF(serial0_uart, 0);
NRF_SERIAL_UART_DEF(serial1_uart, 1);
    ret_code_t ret;
    ret = nrf_drv_clock_init();
    APP_ERROR_CHECK(ret);
    ret = nrf_drv_power_init(NULL);
    ret = app_timer_init();
    //bsp_board_leds_init();
    //bsp_board_buttons_init();
    ret = nrf_serial_init(&serial0_uart, &m_uart0_drv_config, &serial0_config);
    ret = nrf_serial_init(&serial1_uart, &m_uart1_drv_config, &serial1_config);
#ifdef TEST_UARTE0
    static char tx_message[] = "Hello nrf_serial 0\n\r";
    ret = nrf_serial_write(&serial0_uart,
                           tx_message,
                           strlen(tx_message),
                           NULL,
                           NRF_SERIAL_MAX_TIMEOUT);
    (void)nrf_serial_flush(&serial0_uart, 0);
#ifdef TEST_UARTE1
     static char tx_message1[] = "Hello nrf_serial 1\n\r";
    ret = nrf_serial_write(&serial1_uart,
                           tx_message1,
                           strlen(tx_message1),
                           NULL,
    (void)nrf_serial_flush(&serial1_uart, 0);
    while (true)
        char c;
        char c1;
#ifdef TEST_UARTE0
        ret = nrf_serial_read(&serial0_uart, &c, sizeof(c), NULL, 10);
        if (ret == NRF_SUCCESS)
            (void)nrf_serial_write(&serial0_uart, &c, sizeof(c), NULL, 0);
#ifdef TEST_UARTE1
        ret = nrf_serial_read(&serial1_uart, &c1, sizeof(c1), NULL, 10);
            (void)nrf_serial_write(&serial1_uart, &c1, sizeof(c1), NULL, 0);
sdk_config.h
