NRF51822 Steps for Upload Bootloader,Softdevice,Application
  Hello Supporter,
I'm going to develop one BLE nrf51822 based custom device. in which i want to use BLE DFU.
i am able to load DFU and APPLICATION with  KEIL uvison 5.
and i am able to load softdevice using openocd
as i done.
first i upload DFU using KEIL
than upload button less DFU application using KEIL
than Softdevice using Openocd
after that run the device ..it's working and it's advertising Buttonless DFU service.
But the problem is when i try to upload it using DFU device doesn't do in DFU mode nor able to upload new application.
so please tell me steps and ROM(Flash) configuration if needed .
and also tell me if any mistake done by me.
and other methods .if available.
i uploaded two pics one for nrf51.config file used with opencd.....
one for DFU rom address..
to verify
when i tried to combine all three file it gives conflict error like this as below link
devzone.nordicsemi.com/.../s310v2-mergehex-bootloader-hex-bootloader_settings-hex-conflict
Thank You,.
  • one other thing i observed that when i upload application + softdevice ,than application working fine,but after when upload dfu..application stop working and when i again upload application again than also application not working .i must have to upload softdevice .once again if i uploaded dfu . it means dfu may overwrite softdevice or something like that or not. i'm not sure
  • Hello vidar thanks,now what to do?
    i'm not able to understand that you said"I see the device type has been changed from xxAC (default) to xxAA, which will reset the project configuration".
    if i changed it AA so what happen by this change change .and should i change it to default ?
    one other thing i used same  AA for application so it's working. so is it right or wrong?
    by default it comes with nrf51422..xxAC i'm using nrf51822 that's why i changed
  • Changing the device type will reset the linker configuration to the default range for that device type. That is, use all available flash and ram. But it should have worked after you updated the settings to the correct values. For some reason, the ram allocation does not seem reflect the changes you made.
    51822_xxAC and 51422_xxAC are identical except that the latter is licensed for use with the ANT protocol stacks (s2xx and s3xx). Suggest to try again with a clean SDK copy without making any changes to the configuration (you may add your own key set). Then verify that the initial stack pointer is >0x20002C00
