sd_ble_gap_scan_start() induces LFO jitter/instability in PWM output
This is a simplified version of the bug, hoping someone has already seen it and can point me in the right direction.
I will have time over the next 24 hours to build and open-source a full project to show how this bug is reproduced, with a video of this on the scope. In the meantime the main points are below.
TLDR: scanning for advertisements causes PWM output on a GPIO to start a low-frequency drift back and forth (jitter).
High-level walkthrough:
a.) we set up as a BLE peripheral:
	/* init board */
	bsp_board_leds_init();
	APP_ERROR_CHECK(
		app_timer_init()
	/* init logging */
	APP_ERROR_CHECK(
		NRF_LOG_INIT(NULL)
	/* ble init */
	ble_stack_init();
	gap_params_init();
	APP_ERROR_CHECK(
		nrf_ble_gatt_init(&m_gatt, NULL)
	services_init();
	advertising_init();
	conn_params_init();
	/* ble run */
	advertising_start();
b.) we init a PWM:
	/* FET output is high-drive */
	nrf_gpio_cfg(OUT_PWMa,			/* pin_number */
		NRF_GPIO_PIN_DIR_OUTPUT,	/* dir */
		NRF_GPIO_PIN_INPUT_DISCONNECT,	/* input */
		NRF_GPIO_PIN_PULLDOWN,		/* pull */
		NRF_GPIO_PIN_H0H1,		/* drive */
		NRF_GPIO_PIN_NOSENSE		/* sense */
	nrf_gpio_cfg_output(OUT_PWMb);
	nrf_gpio_cfg_output(OUT_PWMc);
	/* start pwm */
	APP_ERROR_CHECK(
		nrf_drv_pwm_init(&pwm0_inst, &pwm0_conf, NULL)
	nrf_drv_pwm_simple_playback(&pwm0_inst, &pwm0_seq, 1, NRF_DRV_PWM_FLAG_LOOP);
c.) We set up a timer:
	APP_TIMER_DEF(a_timer);
	APP_ERROR_CHECK(
		app_timer_create(&a_timer, APP_TIMER_MODE_REPEATED, a_func)
	APP_ERROR_CHECK(
		app_timer_start(fader_timer,
			APP_TIMER_TICKS(1000 / (pwm0_conf.top_value * 0.5)),
			NULL
d.) We scan for bluetooth advertisements:
	/* scan for other devices */
	static ble_gap_scan_params_t scan_params = {
		.active = 0,
		.use_whitelist = 0,
		.adv_dir_report = 0,
		.interval = APP_ADV_INTERVAL,	/* same interval as advertisement */
		.window = APP_ADV_INTERVAL,	/* no idea what this does */
		.timeout = 0			/* never time out */
	APP_ERROR_CHECK(
		sd_ble_gap_scan_start(&scan_params)
When commenting out the scanning in d.) the PWM is rock-solid; with d.) I get fluctuation.
It doesn't matter what I do (or don't do) in the callback handler for bluetooth (even if it's a nop I get the same result).
Removing the timer code makes no difference.
nRF52830 (nRF52-DK)
nRF5_SDK_14.2.0_17b948a
s132_nrf52_5.0.0_softdevice.hex
gcc-arm-none-eabi-7-2017-q4-major
