NRF52832 Maximum number of central links
hi , endnode, I has changed app_util.h as this link
https://devzone.nordicsemi.com/f/nordic-q-a/26448/nrf52832-maximum-number-of-central-links/104059#104059
 the max link count has changed from 15 to 16, how can i set 20?
error log:
..\..\..\main.c(94): error:  #29: expected an expression
  BLE_LBS_C_ARRAY_DEF(m_lbs_c, NRF_SDH_BLE_CENTRAL_LINK_COUNT);           /**< LED Button client instances. */
..\..\..\main.c(95): error:  #29: expected an expression
  BLE_DB_DISCOVERY_ARRAY_DEF(m_db_disc, NRF_SDH_BLE_CENTRAL_LINK_COUNT);  /**< Database discovery module instances. */
..\..\..\main.c: 0 warnings, 2 errors
sdk_config.h:
// <o> NRF_SDH_BLE_PERIPHERAL_LINK_COUNT - Maximum number of peripheral links.
#ifndef NRF_SDH_BLE_PERIPHERAL_LINK_COUNT
#define NRF_SDH_BLE_PERIPHERAL_LINK_COUNT 0
// <o> NRF_SDH_BLE_CENTRAL_LINK_COUNT - Maximum number of central links.
#ifndef NRF_SDH_BLE_CENTRAL_LINK_COUNT
#define NRF_SDH_BLE_CENTRAL_LINK_COUNT 17
// <o> NRF_SDH_BLE_TOTAL_LINK_COUNT - Maximum number of total concurrent connections using the default configuration.
#ifndef NRF_SDH_BLE_TOTAL_LINK_COUNT
#define NRF_SDH_BLE_TOTAL_LINK_COUNT 17
app_util.h
#define MACRO_REPEAT_FOR_0(n_list, macro, ...)
#define MACRO_REPEAT_FOR_1(n_list, macro, ...)  macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_0((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
#define MACRO_REPEAT_FOR_2(n_list, macro, ...)  macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_1((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
#define MACRO_REPEAT_FOR_3(n_list, macro, ...)  macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_2((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
#define MACRO_REPEAT_FOR_4(n_list, macro, ...)  macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_3((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
#define MACRO_REPEAT_FOR_5(n_list, macro, ...)  macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_4((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
#define MACRO_REPEAT_FOR_6(n_list, macro, ...)  macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_5((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
#define MACRO_REPEAT_FOR_7(n_list, macro, ...)  macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_6((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
#define MACRO_REPEAT_FOR_8(n_list, macro, ...)  macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_7((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
#define MACRO_REPEAT_FOR_9(n_list, macro, ...)  macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_8((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
#define MACRO_REPEAT_FOR_10(n_list, macro, ...) macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_9((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
#define MACRO_REPEAT_FOR_11(n_list, macro, ...) macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_10((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
#define MACRO_REPEAT_FOR_12(n_list, macro, ...) macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_11((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
#define MACRO_REPEAT_FOR_13(n_list, macro, ...) macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_12((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
#define MACRO_REPEAT_FOR_14(n_list, macro, ...) macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_13((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
#define MACRO_REPEAT_FOR_15(n_list, macro, ...) macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_14((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
#define MACRO_REPEAT_FOR_16(n_list, macro, ...) macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_15((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
#define MACRO_REPEAT_FOR_17(n_list, macro, ...) macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_16((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
#define MACRO_REPEAT_FOR_18(n_list, macro, ...) macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_17((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
#define MACRO_REPEAT_FOR_19(n_list, macro, ...) macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_18((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
#define MACRO_REPEAT_FOR_20(n_list, macro, ...) macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_19((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
    I got the exact same result here when trying to reproduce.
    It turns out, at least in SDK 14.2, you have to also change the line
    #define MACRO_MAP_FOR_N_LIST 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15
    to
    #define MACRO_MAP_FOR_N_LIST 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20
    in order for the REPEAT_FOR macro to work.
    Terje
  • oh, I find a new problem now.
    change the max link count to 20
    #define NRF_SDH_BLE_CENTRAL_LINK_COUNT 20
    #define NRF_SDH_BLE_TOTAL_LINK_COUNT 20
    The project has Compiled succssfully and passed,but i download it in the board , the project is not run.if change the max link count from 20 to 8, that is ok.
    Are there any other places to be modified?
  • i has solved this problem, it need to adjust the memory address, you can get this message by the log output.
  • I had  change the memory size  just as  start: 0x20007D38    and   size: 0x82C8
    but my board is no work!
    the uart show error:
    <in?<info> app: Multilink example started.
    <info> app: Start scanning for device name Nor?<info> app: Multilink example started.
    <info> app: Start ?<info> app: Multilink example started.
    <info> app: Start scanning for device name Nordic_Blinky.
    <info> app: err is :0
    <info> app: Start scanning for device name N?
    can you help me ?
