valid app check inside bootloader code
Hello to all, i'm new to nRF51822 ble developing but have experience with embedded design on various microcontroller;
I have a little problem inside bootloader code: in order to properly launch the application (if it is present) i perform a simple check using the function bootloader_app_is_valid (from the ble_dfu example from Nordic) to verify if a valid app is stored into the flash;
Initially this code seemed to work but now it is just not working anymore: it seems that also when the application is correctly flashed into the micro, the code above detects no valid application stored but i can't figure out the reason; the bootloader code is the same while the application code is changing (due to my develop). I have also tried to reflash an old app code which i remembered to work togheter with bootloader but the result now is the same.
I am using pure eclipse-gcc projects under eclipse kepler: for the application my project is derived from that posted by Nikita here devzone.nordicsemi.com/.../ , for the bootloader (ble dual bank configuration) my project is derived from that posted by Nguyen Hoan Hoang here devzone.nordicsemi.com/.../
i am also using nRFgo studio within jlink arm to upload all the softwares to the nRF51822, currently i am using the nRF51822DK development kit board.
Any idea on what is happened or how can i update my code to check if a valid application is stored into the flash?
thanks to all Max
