Problems with using Flash and fstorage
I am playing with flash and fstorage lib. I finally got it up and running - I can write and read to flash without having fatal errors. But it's not working as expected. I write "hello world" to 0x3E000 and right after I read some crappy string from that address.
So I tried the flash_fstorage example, compiled and run and I can see the same behaviour. See the output from the logs:
What is going wrong? Do I have my flash somehow corrupted?
Thank you.
EDIT 1:
I tested with another board. I erased the memory (make erase) and then flashed and run the flash_fstorage. The result is the same, only the string that I read back is different: "hL(o world".
EDIT 2:
nrf_fstorage_write() fires a NRF_FSTORAGE_EVT_WRITE_RESULT event which I can handle with evt_handler() from NRF_STORAGE_DEF. But nrf_fstorage_read() DOES NOT fire any event of this type - the evt_handler is not called. Why?
This is my evt_handler implementation:
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
switch (p_evt->id) {
case NRF_FSTORAGE_EVT_WRITE_RESULT:
NRF_LOG_INFO("--> storage Event received: wrote %d bytes at address 0x%x.", p_evt->len, p_evt->addr);
case NRF_FSTORAGE_EVT_ERASE_RESULT:
NRF_LOG_INFO("--> storage Event received: erased %d page from address 0x%x.", p_evt->len, p_evt->addr);
case NRF_FSTORAGE_EVT_READ_RESULT:
NRF_LOG_INFO("--> storage Event received: unknown action %d, %d page @ address 0x%x.", p_evt->id, p_evt->len, p_evt->addr);
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
