Hello all,
As i want to lower the power consumption, may i know if its possible to connect the supply voltage of ntc thermistor to any gpio of nrf52832 instead of directly to the battery?
Thanks.
Hello all,
Thanks.
Are you thinking about doing something like this?
If that is what you're asking, then yes: you can use a GPIO output as the voltage source for such a circuit. Just note that if your NTC is of a very low resistance (less than 1k), you may have to configure the GPIO_OUTPUT as "HIGH_DRIVE" in NRF_GPIO->PIN_CNF[GPIO_OUTPUT], field "DRIVE".
Håkon
