I am trying to implement a timer using nrf_drv_timer.h and nrf_timer.h, however, the handler never gets called.
I first create a timer, then define a timer handler and finally write the init function that also enables the timer.
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(0);
static void timer_handler(nrf_timer_event_t event_type, void * p_context)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "In timer handler\n");
typedef enum
APP_SIMPLE_TIMER_MODE_SINGLE_SHOT, /**< The timer will expire only once. */
APP_SIMPLE_TIMER_MODE_REPEATED /**< The timer will restart each time it expires. */
} app_simple_timer_mode_t;
void timer_init(void) {
ret_code_t err_code;
timer_cfg.mode = NRF_TIMER_MODE_TIMER; ///
timer_cfg.frequency = (nrf_timer_frequency_t)4;
if (NRF_SUCCESS == err_code)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "SUCCESS\n");
else {
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "NO\n");
/* setup m_timer for compare event every 400ms */
uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 400);
NRF_TIMER_CC_CHANNEL0,
ticks,
NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
true);
Any suggestions?
