turning on/off a LED by toggling a GPIO pin using a timer and PPI
Application: turning on/off a LED by toggling a GPIO pin using a timer and PPI. Important: the on-time of the LED must be very precise, i.e. the jitter must be minimal.
I used the example "gpiote" found in the SDK and changed the toggle frequency in led_blinking_setup() in order to get a LED0 on-time of 20ms. When I measured the on-time of LED0 using a LeCroy waveRunner 64Xi I observed that there is a jitter of up to 70us (!).
My questions:
What is the reason for this high jitter?
Is it possible to reduce the jitter?
Would it be possible to replace the 32 MHz quartz with a more stable oscillator?
Where do I find more electrical specifications of the processor (timing of PLL, IOs, etc)?
Thanks for you help
Felix
