when put a function in main , the current is about 0.3mA
like this:
bool gm_judge_obd_no_data(void)
    if(m_obd_auto_info.rpm > 10)
        return false;
    return true;
void gm_vel_dispaly_process(void)
    switch(m_vel_dispaly_process)
        case VEL_DIS_PROCESS_SLEEP :
            if(gm_judge_obd_no_data() == false)
                m_vel_dispaly_process = VEL_DIS_PROCESS_AWAKEN_INIT;
        default :
    timer_init();
    gm_init_ht16c23();
    ble_stack_init();
    gm_set_device_adv_name();
    gap_params_init();
    gatt_init();
    conn_params_init();
    db_discovery_init();
    peer_manager_init();
    services_init();
    advertising_init();
    gm_open_dcdc_mode();
    application_timers_start();
    adv_scan_start();
    //------------1
    for (;;)
        //------------2
        power_manage();
when device sleep, some used peripherals were closed,  m_vel_dispaly_process = VEL_DIS_PROCESS_SLEEP;
now, in function "gm_vel_dispaly_process();" , change "m_vel_dispaly_process " according to the result of check  "uint8_t m_obd_auto_info.rpm" greater than 10 or not.
if put "gm_vel_dispaly_process();" in "//------------1", current about 0.01mA, however put in "//------------2", current  is 0.3mA.
even if put "gm_vel_dispaly_process();" in a function for handling timer timeout(1 s), still 0.3mA.
if delete "power_manage();" in main, modify and put "gm_vel_dispaly_process();" in for(;;){}, current  is 0.3mA.
                 power_manage();
        default :
    Could you post/upload your test program?
    Håkon
  • sorry,it belongs to the company,i revise the question. thank u.
    Sorry for the late reply.
    Is there anything that m_vel_dispaly_process or any of the other variables in the function "gm_vel_dispaly_process" that are processed asynchronously in a timer interrupt or similar that might account for this sleep current?
    Håkon
