Regarding twi sensor
Dear Sir,
I am using nrf52832 & sdk 14. When I dump your twi sensor code(SDK14\nRF5_SDK_14.2.0_17b948a\examples\peripheral\twi_scanner\pca10040\blank\arm5_no_packs) in the nrf52832 development kit there is no activity observed on the oscilloscope on the pins SCL(P0.27) & SDA(P0.26).
But when I tried the same thing on nrf51422, I got the clock pulses.
So please tell me what is the problem with the nrf52832 & sdk 14 (I have tried this with sdk12 also).
Manoj Hiwarkar.
    As long as you haven't modified anything, the scanner example and the PCA10040 should work out of the box. Have you double checked that you are using the correct pins? The default pins are configured in pca10040.h as:
    #define ARDUINO_SCL_PIN             27    // SCL signal pin
    #define ARDUINO_SDA_PIN             26    // SDA signal pin
    which should be correct in your case.
    Have you connecte anything else than your scope to the pins?
  • No, I have not modified anything, the scl & sda pins are defined exactly as shown above. And I have also not connected anything other than DSO pins.
  • 1.Yes I have tried with P0.24 & P0.25.
    2. We have our target board , but we don't have another kit.
  • I tested your code and it worked out of the box. I used
    • An MPU9255 as slave (shouldn't matter though as long as you have functional slave device?)
    • PCA10040 development kit
    • SDK 14.2.0
    • And these pins:
    I have attached my .hex file. Can you try to program it to your kit and see if it works? If it doesn't, then your kit, or possibly any attached slave devices, seems to be broken. I have seen other cases where things work on my system, but not on the customer's, and in one particular case it turned out that the customer had changed his driver files and forgotten about it. Hence, it worked when I compiled the code with my original SDK files, but not when he compiled it with his modified files. So make sure to use original drivers.
  • The twi sensor code is working now. The problem was in pack installation. But now the thing is I am not able to configure the pins P0.09 & P0.10 as SCL & SDA. Other pins are getting configured.
  • I am getting the clock pulses on SCL & SDA  pins of the target board. But still I am not getting the data from the max30205. I am herewith uploading the two videos (both are with different time base) these clock pulses on the oscilloscope.
    Blue line is SDA
    Yellow line is SCL
    So please tell me where I am going wrong.
    Blue line is SDA
    Yellow line is SCL
