background scanning
i used nRF5_SDK_14.1.0_1dda907.
ANT protocol :
I used ant_background_scanning example.
I want to scannig device ID of hrm, bpwrt and bsc.
Then choose the device ID for received ant+ packet.
What is the function that can stop scanning mode?
Or, what is the way that achieve the situation that scan device ID then choose the device ID for received packet?
  • Hi, the number of ANT channels that can be open at any given time is set when calling sd_ant_enable() with ucTotalNumberOfChannels.
    If one of the channels is a background scanning channel with low priority search, then there is no problem to configure more channels that can be used to track a single device. The procedure to setup a second ANT channel is the same as always by assigning, setting channel ID, network keys, period, frequency,... and finally open channel. You can close and unassign a channel as always, even background scanning channel.
