nRF52832 IO problem
Hello!
We have nRF52832 chip on our product and we have some problem with one of its IOs.. We configured P0.16 as RX of UART, And when we run it we see this behavior of this IO:
VCC (yellow) vs P0.16 (green) that configured as UART_RX
Here we see that with rising of VCC (yellow signal) IO (green) rising to almost 1V when it supposed to still at 0V. Important note: we disable and enable VCC fast here so we see that before rising of VCC it don't have 0V. This behaviour is very problematic to our system. Because we have power supply sensitive sensor that connected to this UART. This spike of voltage damage sensor that connected to this IO.
We tried to load to evaluation board same version of SW on nRF52832 and we got next result:
We see that also here we have the problematic spike.
When we erased the evaluation board - we got the same result.
Is this IO known as problematic?
Thank you
  • There will be some small start-up time for the buck but it is probably very minimal.  It sounds like your timing is very critical between the NRF and your sensor.  Perhaps it makes sense to wait for a delay (a few mS) after startup, then have your NRF pull the reset line of the MSP430, and then start your communication.  This way you can guarantee that everything is fully powered up before you try to pass data between the micros.
    Even with that said, I still do not understand why your UART RX line is low even when there is a 100k pull-up.  If that condition is still there even after everything has been powered up and configured, there is a hardware problem or a configuration problem somewhere and that issue needs to be resolved before going any further.
  • I did the test and it seems ok:
    Yellow is 9V, green is nRF 3.3V and blue is on-sensor buck 3.3V
  • Even with that said, I still do not understand why your UART RX line is low even when there is a 100k pull-up.  If that condition is still there even after everything has been powered up and configured, there is a hardware problem or a configuration problem somewhere and that issue needs to be resolved before going any further
    At screenshots at first topic there are still no pull-up so here the IO start at low. We tried pull-up 100k and it worked as expected - at start-up it pulled to 3.3V as needed.
  • If we back up a little bit, why did you get to the conclusion that the small spike on power-up of the NRF damaged your MSP430?
    Have you tried putting your scope on the TX/RX lines of the UART once everything is powered up, in order to verify that there is serial traffic from whichever micro is supposed to start talking first?
  • Looks like a classic phantom power issue, which I mention earlier in this thread, given the MSP430 powers up long before the nRF SoC. If there are other devices attached (host MCU or external serial port to PC etc) care is required to ensure no port pins are driving into the nRF52832 SoC during a power-down period. In a simple system with a host MCU typically a UART Rx, Tx and the nRF52832 SoC RST pins will be connected between host MCU and nRF52832 SoC. In that simple case either Rx or Reset pins will phantom power the entire nRF52832 SoC if they are left driven high while nRF52832 SoC power is removed. This is perhaps not unexpected if we assume dual internal schottky diode protection (a clamp diode to both GND and VCC) instead of single internal schottky diode (to GND with low breakdown voltage). This means that to power-down the nRF52832 SoC the MCU code must first drive both UART RX and BLE RST pins low, otherwise the supply of (say) 3 volts only drops to 2 volts or so when the supply is switched off and the nRF52832 SoCtherefore does not reset.
    In a similar manner, connecting a typical FTDI USB serial port to the nRF52832 SoC can unexpectedly phantom power the part, and stop it correctly resetting or powering down unless the FTDI is first removed. This can cause confusing and unexpected behavior. There is an excellent Dialog publication Training_07_DA1458x_prototype_bring_up_guide _Training_07_DA1458x_prototype_bring_up_guide -v1. 2I 2I_ which actually touches on this without mentioning why:
    It is recommended that P0_4 and P0_5 are made available for UART communication during production test and board bring-up. Note that, if the two pins are also used as interface to an external MCU, that this MCU will need to be able to high-Z the pin connected to P0_5
    The reason is that resetting the test board doesn't work correctly unless drive to the Rx pin is first removed, including drive from any connected FTDI USB serial port or driving low or floating any connected host MCU.
    The MSP430 port pin may not survice powering up the entire nRF Soc; if you can't stop the MSP430 line driving to the nRF then perhaps add a series current-limiting resistor.
