I am trying to track down a fatal error and want to use the Error module as documented below, to get the line number and file name.
Using eclipse, where should DEBUG be set. So far I have tried sdk_config.h file with the following addition:
#ifndef DEBUG
#define DEBUG 1
However this is only giving me the PC and I am not getting through to app_error_save_and_stop where the line number and filename should be determined. Is this the correct way to set the DEBUG flag?
If the DEBUG flag is set:
When app_error_fault_handler is invoked, the error info (for example the function parameters: error code, line number, and file name) are copied to global memory, interrupts are disabled, and the application enters an infinite loop.
