xdata & sleep issue
Good morning, I want my nRF24LE1 to sleep & wake up (memory retention, timers on) while retaining data in xdata, but it's not doing so. Please help!! Thanks, Mahesh
For example, there's a 2D array,
uint8_t xdata _p_outbufs[5][32]
that does not survive a sleep/wake cycle. some of the other variables are persisted, but not all. i can't figure out why. i've attached the .M51 file. i also have below the list of all variables and their (pointer) locations.
all values for _p_outbufs[5][32] are set to 0x55 just before it goes to sleep:
0: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55
1: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55
2: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55
3: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55
4: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55
after waking up, the values are NOT the same anymore:
0: F4 F0 F0 F8 8F 0F 0E 0E F8 F0 B0 F4 02 0F 0E AF D0 B0 D0 F0 2F 8F 0D 07 E0 F0 E0 F0 2D 8F 0F 0F
1: F0 F0 F0 F1 46 8F 4F 3F F0 70 70 F8 0F 2F 2E 0D E0 E0 C0 E0 0F 0F 0F 0F F0 F0 F0 E2 4F 0F 0F 0B
2: F1 F4 E0 F0 1F 0D 0B AF F0 F0 B0 F2 4F 15 07 8F 98 F0 F0 F0 1D 0F 1F 7B F0 D8 F4 F0 0B CF 8F 0D
3: E0 F1 F1 F0 0E 0F 0F 0D 20 20 7A D9 0F 03 0F 07 F0 70 F0 F0 F9 C8 F0 F0 07 0D 0F 1E F2 F0 F0 F0
4: 0F 8F 0F 1F F0 B0 F2 F0 0E 0E 0F 0F F0 F0 F0 F3 0F 03 0F 0E B0 F0 F4 F0 0E 0E 0E 0A F0 F0 E0 E0
here are the variables i'm using, and the pointer locations they report within the program. some of the pointer values match those in the .M51 file, others do not.
POINTERS:
uint8_t xdata _p_inbufs[IN_BUF_NUM][PACKET_SIZE_MAX]: x:00ca
uint8_t xdata _p_outbufs[OUT_BUF_NUM][PACKET_SIZE_MAX]: x:020c
xdata BufQueue inbufs: x:003a
xdata BufQueue outbufs: x:0042
uint8_t code code_ex: i:0042
uint8_t xdata xdata_ex: -:0042
uint8_t data data_ex: i:0042
uint8_t idata idata_ex: i:0042
uint8_t pdata pdata_ex: -:0042
uint8_t xdata packet_id: -:0042
uint8_t* packet: x:00ca
uint8_t xdata mad[MAC_ADDR_LEN]: x:00c4
uint8_t xdata payload[PACKET_SIZE_MAX]: x:02c5
uint8_t xdata params[P_MAX]: x:0021
uint8_t xdata mul: i:0021
uint16_t xdata status: -:c021
uint16_t* xdata sleep: x:0023
uint16_t* xdata adc_values: x:000d
uint8_t xdata adc_stack_pointer: i:000d
uint8_t xdata adc_packet[PACKET_SIZE_MAX]: x:0001
uint8_t xdata rx2[PACKET_SIZE_MAX]: x:004f
uint8_t xdata packet1[PACKET_SIZE_MAX]: x:00a4
char xdata name[NAME_MAX_LEN]: x:0094
uint16_t xdata request_id;: -:1094
uint16_t xdata response_id: i:0094
bool radio_busy: i:0094
bool tx_err: i:0094
uint8_t irq_flags: -:0094
bool got_ack_pack: i:0094
bool data_recd: i:0094
uint8_t len: -:0094
leakspotter.M51
    Memory retention retains only the first 512 byte block of memory, while the upper 512 bytes are powered off. Here's a snippet from chapter 7 in the PS:
    A special feature of the nRF24LE1 SRAM block is that it is composed of two physical 512 byte blocks called DataRetentive (lower 512 bytes) and DataNonRetentive.
    DataRetentive, in contrast to DataNonRetentive, keeps its memory content during the Memory Retention power down modes (see chapter 11 onpage 105).
    Could you try absolute placement on the buffers that you need retained (using the _at_ keyword)?
    Cheers,
    Håkon
  • Hi Håkon,
    What is the memory range that's retained? Could you take a look at the .M51 file i sent and see if the storage area for _p_outbufs falls within that range?
    Also, could you give me an example of using the _at_ keyword that falls within the retention range?
    Thanks!
    Mahesh
  • Hi Håkon,
    A. does Fig. 37 & table 26 mean that the 2 data blocks are *always* contiguous?
    B. please confirm: the blocks can be set to be EITHER location; there are NOT two sets of blocks at both 0x0000 - 0x03FF AND 0x8000 - 0x83FF. i have to choose one of the two.
    B. isn't code already stored in non-volatile memory? what is the use of marking the SRAM data blocks as code?
    C. in the example i gave, all the values of _p_outbufs[][] are set to 0x55, but get changed to a different data pattern (F4 F0 F0 F8...) which is always the same at every wake-up. it isn't a random loss of memory. any idea what is actually happening?
    D. _p_outbufs starts at 0x020C in the .M51 file, which is outside the retentive range of 0x0000-0x01FF, if SRAM starts at 0x0000 by default. this might be my problem.
    E. i was looking at the _at_ keyword yesterday :-). please confirm: if i use the _at_ keyword, i'm responsible for any conflicts between THOSE variables. the compiler will handle the rest. so if i have two variables at the same absolute location, it won't flag an error. this might be useful for union-like behavior.
    Mahesh
  • Hi, I was able to get retention using the _at_ keyword and moving variables, thanks!!! even so, could you still give me answers to the questions above? i believe the answers are:
    A. Yes.
    B. Yes.
    B. (should be C). i don't know the answer to this -- why does code need a memory retentive block? isn't all code already retained?
    C. why does this happen?
    D. Yes, that was the problem.
    E. if there's an overlap between absolute placement of variables, the compiler raises a warning. does this mean that i could deliberately superimpose two variables, e.g.
    uint8_t xdata a[2] _at_ 0x004;
    uint16_t xdata b _at_ 0x004;
    a[0]=0xFF;
    a[1]=0xEE;
    the value of b will be 0xEEFF. is that correct?
    B & C:
    Only half of the RAM (512 bytes of a total 1k) is retained in "memory retention":
    DataRetentive is the retained block (powered block in PWRDWN=2 or 3), while the upper 512 bytes are turned off to lower power consumption.
    If you want all the RAM powered in sleep, I'd recommend to use "register retention" (PWRDWN=4;).
    RegisterRetention does not cause a reset upon wakeup either, which can be beneficial.
    E:
    The compiler should give you a warning, or possibly a linker error, if you try to do this.
    This would be the same as this:
    uint8_t xdata a[2] = {0xFF, EE};
    uint16_t xdata *b = a;
    And that should give b=0xEEFF.
    The linker will organize your data to ensure that variables with the _at_ keyword is not conflicting with variables declared without it.
    Håkon
