Observing reduced TX packets per connection interval in SDK 14.2 vs SDK 12.2
We have recently ported our application from SDK 12.2 to SDK 14.2. The application is very power sensitive and uses a high connection interval and slave latency to minimise power consumption at idle:
#define MIN_CONN_INTERVAL (SECOND_1_25_MS_UNITS / 100) * 30 /*300ms*/
#define MAX_CONN_INTERVAL (SECOND_1_25_MS_UNITS / 100) * 39 /*390ms*/
#define SLAVE_LATENCY 4
#define CONN_SUP_TIMEOUT (6 * SECOND_10_MS_UNITS) /*6s*/
The application is a datalogger and occasionally needs to send a few thousand bytes of data in the peripheral -> central direction.
In SDK 12.2 we were able to send significant numbers of packets per connection interval during these data transfer events - we would see upwards of 30 packets transmitted per 300ms interval. This was maintained consistently no matter how much data was sent (we are careful to keep the TX buffer full so there is always more data to send).
However, in SDK 14.2 we see a similar number of packets going out during the very first connection interval but then the throughput rate drops off markedly, with only four packets per connection interval being transmitted from the second connection interval onwards. Essentially the link is now sitting idle for nearly 80% of the time, despite the TX buffer being full with data to send.
The only thing that has changed is the SDK - the hardware for the peripheral is the same and the software on the central (an iPhone) is unchanged. Similarly the software running on the peripheral is unchanged except for API tweaks as required to support the new SDK.
What could have caused this change in behaviour between SDK versions? Is there some additional config we need to set in SDK 14.2 to ensure we are not limited to transmitting only 4 packets per connection interval?
Any help gratefully received!
  • Hi
    Could you try increasing the NRF_SDH_BLE_GAP_EVENT_LENGTH parameter in sdk_config.h?
    If you have a long connection interval then this could limit the number of packets you are able to send on each connection event.
    Best regards
    Torbjørn
  • We managed to solve this issue by explicitly reducing the connection interval during the transfer events using sd_ble_gap_ppcp_set, then increasing it again when the transfer event has finished.
    Strangely though when we make the second call (after the transfer has finished) we get an NRF_ERROR_BUSY response for quite some time - around 20 seconds after the transfer completes. To ensure the connection interval definitely does revert to the longer setting we've had to set up a timer that calls sd_ble_gap_ppcp_set repeatedly until a NRF_SUCCESS response is received.
    What might possibly cause this behaviour? Is there any way to see what the softdevice is busy doing? There is no data transfer happening when this occurs.
  • Hi
    Sorry for the slow response.
    I will check this with the stack team and get back to you.
    What SoftDevice type and version are you using?
    Best regards
    Torbjørn
