Setting TX power level in S120
When is the most appropriate time to set the transmit power while using the S120 softdevice? I want to set it once at power up. Most examples that use the S110 SD set the power level in their gap_params_init() function.
I've added the call to sd_ble_gap_tx_power_set() at the end of my ble_stack_init() function. It appears to succeed but I'd like to know if there are any timing requirements that dictate that it should be called at some other time.
    SDK manual does not state anything particular about how and when use sd_ble_gap_tx_power_set(), so, I suppose is safe to use where you think it could fit better with your needs.
    A note about which type of error the function call may return, in S120 documentation seems there are only two errors type (NRF_SUCCESS and NRF_ERROR_INVALID_PARAM) while in S110 there is one more error : NRF_ERROR_BUSY.
    Maybe a typo !!
    -c
