nRF52832 as writable NFC tag 2. Is it possible?
Hello dear
I have a question about NFC on RF52832. On section 42 of datasheet, says:
"The NFCT peripheral (referred to as the 'NFC peripheral' from now on) supports communication signal type A and 106 kbps bit rate from the NFC Forum. With appropriate software, the NFC peripheral can be used to emulate the NFC- A as specified by the NFC Forum. Listed here are the main features for the NFC peripheral:
• NFC-A listen mode operation
• 13.56 MHz input frequency
• Bit rate 106 kbps
• Wake-on-field low power field detection (SENSE) mode
• Frame assemble and disassemble for the NFC-A frames specified by the NFC Forum
• Programmable frame timing controller
• Integrated automatic collision resolution, CRC and parity functions "
However on some posts about NFC on devzone, I understood that hardware is compatible with writable NFC tag, but the library on sdk does not support this feature. This is correct? Some one implemented it?
