Panic while deleting a peer entry after device reset
Hi all,
I am using SDK14.1.0
Steps of my execution are -
1) My requirement is to make bond when making connection to the android APP. I have done following initialization sequence-
log_init();
 timers_init();
 //System API for schedule initialisation - queue size 10
 ble_stack_init();
 gap_params_init();
 gatt_init();
 advertising_init();
 services_init();
 conn_params_init();
 peer_manager_init();
 //Application API for initialisation of device configuration
 init_configuration();
 //Application API for setting of device configuration - LED- buzzer beeps/blink ,interval settings etc
 set_configuration();
 //System API for BLE advertising status check timer: timeout same as advertising timeout
    delete_bond();
  // No bond deletion at reset for now!!!!!
 // Enter main loop.
Bond was created after connection with Phone.
2) Do hardware reset. In device initialization I want to delete all the bonds created in step (1). I have called following function for delete bond
void delete_bond(void)
 ret_code_t  err_code;
 err_code = pm_peers_delete();
 NRF_LOG_INFO("delete bond error code = %d",err_code);
 // disable the autoconnection in case of bond deleted.
 AUTOCONNECTION_ENABLE = false;
But I am getting a fatal error at Following code
    NRF_LOG_INFO("Erase bonds!");
Please suggest me for any sequence correction or wrong function usage. You can refer to any sample too that can showcase bond deletion logic.
sandeep
