nrf52832 sparkfun breakout board program with SDK14.0.2
Hello everyone! I am trying to program a nrf52832 sparkfun board through a nRF52DK. I have already gone through the pin connection guide succesfully and I can flash succesfully hex files which however do not seem to work a least with SDK14.0.2. As I have read here and here sparkfun's board comes with pre-programmed bootloader(compatible however with SDK 11) in order to be compatible with arduino IDE? So what procedure should I follow if I want to run code for SDK14.0.2? Should I define a custom_board header only and if yes where should i put this definition? Or for my examples I must create a new directory structure for the new board like those already existing for PCA10040? Do I need to build and flash a new bootloader for current SDK? If yes,can you please provide a guide for that? As you can understand I have turned a bit confused! Any help is appreciated! Thank you in advance!
