Using GPIOTE with softdevice returns FATAL ERROR
I wrote this code to make a 1MHz signal clock with timer and GPIOTE.
#include "mclk.h"
static nrf_drv_timer_t timer = NRF_DRV_TIMER_INSTANCE(0);
void timer_dummy_handler(nrf_timer_event_t event_type, void * p_context){}
void mclk_init(void)
    ret_code_t err_code;
    nrf_drv_timer_config_t timer_cfg =
		.frequency          = (nrf_timer_frequency_t)3,
		.mode               = (nrf_timer_mode_t)TIMER_DEFAULT_CONFIG_MODE,
		.bit_width          = (nrf_timer_bit_width_t)TIMER_DEFAULT_CONFIG_BIT_WIDTH,
		.interrupt_priority = 0,
		.p_context          = NULL
    err_code = nrf_drv_timer_init(&timer, &timer_cfg, timer_dummy_handler);
    // Setup PPI channel with event from TIMER compare and task GPIOTE pin toggle.
    uint32_t compare_evt_addr;
	uint32_t gpiote_task_addr;
	nrf_ppi_channel_t ppi_channel;
	nrf_drv_gpiote_out_config_t config = GPIOTE_CONFIG_OUT_TASK_TOGGLE(false);
	err_code = nrf_drv_gpiote_out_init(MCLK_PIN, &config);
	nrf_drv_timer_extended_compare(&timer, (nrf_timer_cc_channel_t)0, 1, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
	err_code = nrf_drv_ppi_channel_alloc(&ppi_channel);
	compare_evt_addr = nrf_drv_timer_event_address_get(&timer, NRF_TIMER_EVENT_COMPARE0);
	gpiote_task_addr = nrf_drv_gpiote_out_task_addr_get(MCLK_PIN);
	err_code = nrf_drv_ppi_channel_assign(ppi_channel, compare_evt_addr, gpiote_task_addr);
	err_code = nrf_drv_ppi_channel_enable(ppi_channel);
	nrf_drv_gpiote_out_task_enable(MCLK_PIN);
    // Enable timer
    nrf_drv_timer_enable(&timer);
It works fine without softdevice, but when I modify my app to use BLE, gpiote doesn't work (I found the problem is GPIOTE when I commented out all lines with it)
My config is
// <e> GPIOTE_ENABLED - nrf_drv_gpiote - GPIOTE peripheral driver
#ifndef GPIOTE_ENABLED
#define GPIOTE_ENABLED 1
#if  GPIOTE_ENABLED
// <o> GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS - Number of lower power input pins
#ifndef GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS
#define GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS 4
// <o> GPIOTE_CONFIG_IRQ_PRIORITY  - Interrupt priority
// <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
// <0=> 0 (highest)
// <1=> 1
// <2=> 2
// <3=> 3
#ifndef GPIOTE_CONFIG_IRQ_PRIORITY
#define GPIOTE_CONFIG_IRQ_PRIORITY 3
// <e> GPIOTE_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef GPIOTE_CONFIG_LOG_ENABLED
#define GPIOTE_CONFIG_LOG_ENABLED 0
#if  GPIOTE_CONFIG_LOG_ENABLED
// <o> GPIOTE_CONFIG_LOG_LEVEL  - Default Severity level
// <0=> Off
// <1=> Error
// <2=> Warning
// <3=> Info
// <4=> Debug
#ifndef GPIOTE_CONFIG_LOG_LEVEL
#define GPIOTE_CONFIG_LOG_LEVEL 3
// <o> GPIOTE_CONFIG_INFO_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef GPIOTE_CONFIG_INFO_COLOR
#define GPIOTE_CONFIG_INFO_COLOR 0
// <o> GPIOTE_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef GPIOTE_CONFIG_DEBUG_COLOR
#define GPIOTE_CONFIG_DEBUG_COLOR 0
#endif //GPIOTE_CONFIG_LOG_ENABLED
// </e>
#endif //GPIOTE_ENABLED
// </e>
But #define APP_GPIOTE_ENABLED 0
If I change APP_GPIOTE will it help?
