SDK 15 GCC making fail
Find big problem with GCC make settings (guess Makefile.common) does not work with SDK 15. with SDK 14.2  same Project works succes.
The Problem : use SDK15 ,  the error :
Compiling file: main.c
toolchain/Makefile.common:272: update target '_build/nrf52840_xxaa/main.c.o' due to: Makefile
arm-none-eabi-gcc: error: =1024: No such file or directory
use SDK14.2 is Ok
I find, for SDK14.2 output folder contains filelist like "nrf52840_xxaa_main.c.o"  : it is OK.
for SDK15, output folder is "./nrf52840_xxaa/" : it is the MISTAKE.
THEN Nordic will fix this problem ?
thanks.
