How is it possible to use ANT and ANT+ at the same time?
I read on ANT documentation that is possible to configure different channels with different network keys.
In my project i write:
>> sd_ant_network_address_set( "ANT+NetworkNumber", "ANT+NetworkKey");       // where ANT+NetworkNumber = 0 and ANT+NetworkKey is the one write on www.thisisant.com
>> sd_ant_channel_assign("ANT+channelNumber","ANT+channelType","ANT+NetworkNumber",0);
// another channel configuration for ANT+
>> sd_ant_network_address_set( "ANTNetworkNumber", "ANTNetworkKey");       // where ANTNetworkNumber = 0 ant ANTNetworkKey is a public network
>> sd_ant_channel_assign("ANTchannelNumber","ANTChannelType","ANTNetworkNumber",0);
The result is that only ANT channel is correctly working as if the second sd_ant_network_address_set called impose the first one.
How can i use ANT and ANT+ at the same time on the same device?
Thanks for your support.
Best regards
Anna
