BUG: BLE_GAP_EVT_ADV_SET_TERMINATED is never raised
By setting either:
ble_gap_adv_params_t::duration
or
ble_gap_adv_params_t::max_adv_evts
to a non-zero value should trigger the BLE_GAP_EVT_ADV_SET_TERMINATED event after specified time / events.
This results in a fatal crash on the connectivity board on my serialization project.
The setup is as follows:
  • SDK 15.0.0
  • SoftDevice S132 v6
  • FreeRTOS 10
  • Transport: SPI5W
The goal I am trying to achieve is to have rotating advertisement packets (similar to the Eddystone project).
The approach is as follows:
  • initialize advertising parameters
  • start advertising
    after some time
  • stop advertising
  • replace adv. parameters after a timeout event (based on timer)
  • start advertising
And repeat this process.
Currently; this fails after 4 attempts; since app_ble_gap_adv_set_register uses a maximum of 4 m_adv_sets.
Can you elaborate on this issue?
Kind Regards,
Justin Brederveld
  • Hi Justin,
    Just wanted to let you know that I am looking into your case. There might be some changes in SDK 15 related to advertisements. Will get back to you as soon as I have more information.
    Ketil
  • Dear Justin,
    I found the same problem today (sdk15-serialization-example-crashes), BLE_GAP_EVT_ADV_SET_TERMINATED is missing in ble_event_enc.c
    #ifndef S112
            case BLE_GAP_EVT_ADV_REPORT:
                ret_val = ble_gap_evt_adv_report_enc(p_event, event_len, p_buf, p_buf_len);
    #endif //!S112
            case BLE_GAP_EVT_SCAN_REQ_REPORT:
                ret_val = ble_gap_evt_scan_req_report_enc(p_event, event_len, p_buf, p_buf_len);
    		case BLE_GAP_EVT_ADV_SET_TERMINATED:
    			ret_val = ble_gap_evt_adv_set_terminated_enc(p_event, event_len, p_buf, p_buf_len);
    And possibly also in your ble_event.c
    #ifndef S112
    #endif //!S112
    Kind Regards,
    Erwin
