pc-ble-driver communication issue
I am trying to establish communication between Win 10 PC and nRF52 Dev Kit using pc-ble-driver. I followed the instructions in:
https://github.com/NordicSemiconductor/pc-ble-driver/blob/master/Installation.md
I successfully programmed the IC using the following commands:
$ nrfjprog -f NRF5<x> -e
$ nrfjprog -f NRF5<x> --program hex/sd_api_v<x>/connectivity_<ver>_<baudrate>_with_s13<v>_<a>.<b>.<c>.hex
Then I am not sure how to make the hear_rate_monitor run on the IC from Windows 10. Instruction is not clear. I flashed ble_app_hrs_pca10040_s132.hex from 14.2 SDK using nrfgo Studio and connected the device on Win 10.
Then I ran the node ../examples/heart_rate_monitor.js and got the follow error:
*******************************************Command Line Output Begins **************************************************
c:\Users\Magnima\Documents>node C:\Users\Magnima\node_modules\pc-ble-driver-js\examples\heart_rate_monitor.js
Searching for connected adapters...
onAdded: Adapter added: 682805666.
Found the following adapters:
682805666
Connected to adapter: 682805666.
Opening adapter with ID: 682805666 and baud rate: 115200...
#BLE_PERIPHERAL: logMessage: Successfully opened COM4. Baud rate: 115200. Flow control: none. Parity: none.
#BLE_PERIPHERAL: status: {
"id": 6,
"name": "RESET_PERFORMED",
"message": "Target Reset performed",
"time": "2018-04-06T04:43:20.474Z"
Failed to open the nRF5 BLE driver.
#BLE_PERIPHERAL: logMessage: UART port COM4 closed..
#BLE_PERIPHERAL: error: {
"message": "Error occurred opening serial port.",
"description": {
"errno": 13,
"errcode": "NRF_ERROR_TIMEOUT",
"erroperation": "opening port",
"errmsg": "Error occured when opening port. Errorcode: NRF_ERROR_TIMEOUT (0xd)\n"
Error: Error opening adapter: Error: Error occured when opening port. Errorcode: NRF_ERROR_TIMEOUT (0xd)
at adapter.open.err (C:\Users\Magnima\node_modules\pc-ble-driver-js\examples\heart_rate_monitor.js:153:31)
at Adapter._checkAndPropagateError (C:\Users\Magnima\node_modules\pc-ble-driver-js\api\adapter.js:273:27)
at _adapter.open.err (C:\Users\Magnima\node_modules\pc-ble-driver-js\api\adapter.js:410:22)
C:\Users\Magnima\Documents>
*******************************************Command Line Output Ends **************************************************
Please advice how to get beyond this error.
    You are not supposed to flash the heart rate application from the SDK. The connectivity firmware will act as a serialized controller for the softdevice. The heart rate application is implemented in the hear_rate_monitor.js script. Flash the connectivity firmware, run the script, and connect to the device with the HRM app in nRF Toolbox on your phone to check that it is working.
    Jørgen
