why BLE_APP_UART example can use button 1 to button 4 to wakeup from sleep?
Hi Expert,
I checked source code I only saw the BTN_ID_WAKEUP  is 0.
#define BTN_ID_WAKEUP             0  /**< ID of button used to wake up the application. */
I use the SDK nRF5_SDK_12.3.0_d7731ad
use the nRF52 DK and nRF51 DK.
    I can see the same behavior that you do. The reason for this is that all the buttons and LEDs are initialized in buttons_leds_init() --> bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS, bsp_event_handler);
    If you disable the interrupts for these pins before enabling only the ones you want, it will only wake up on those button presses.
    Your sleep_mode_enter() function should look something like this then:
        //disable old button interrupts
        nrf_drv_gpiote_in_event_disable(13);
        nrf_drv_gpiote_in_event_disable(14);
        nrf_drv_gpiote_in_event_disable(15);
        nrf_drv_gpiote_in_event_disable(16);
        // Prepare wakeup buttons.
    Edvin
