Hi
I have a problem with long latency on interrupts and long delay on retriggered interrupt.
I have a nRF52832 running with external HFCLK source. Using the SDK 14.2.0. The softdevice is disabled before using the GOIOTE and re-enabled afterwards.
The GPIOTE is setup like this:
if (!nrf_drv_gpiote_is_init()) { err_code = nrf_drv_gpiote_init(); APP_ERROR_CHECK(err_code); } nrf_drv_gpiote_in_config_t config = GPIOTE_CONFIG_IN_SENSE_HITOLO(true); nrf_drv_gpiote_in_init(RFID_PIN_DOUT, &config, gpiote_void_handler); nrf_drv_gpiote_in_event_enable(RFID_PIN_DOUT, true);
As you can see I have skipped the original interrupt service routine from the SDK and wrote my own to avoid the overhead.
My interrupt service routine is like this:
void GPIOTE_IRQHandler(void) // DOUT call back handler { // Clear the GPIO event NRF_GPIOTE->EVENTS_IN[0] = 0; // Mark start of interrrupt NRF_P0->OUTSET = 1 << RFID_PIN_TEST1; /* Interrupt code here. Takes around 2µs */ // Mark end of interrrupt NRF_P0->OUTCLR = 1 << RFID_PIN_TEST1; }
I got a latency of 1.6 µs from the falling edge on GPIO pin RFID_PIN_DOUT to the rising edge of RFID_PIN_TEST1.
An if an additional falling edge occurs before the interrupt service routine, there is a delay between the falling edge of RFID_PIN_TEST1 to the next rising edge also on 1.6 µs.
I had expected much lower latency on a 64MHz processor. It should take around 16 clock cycles to enter or leave the interrupt service routine, which is 0.25µs.
The big question: What does the MCU do en the rest of the time?
