SDK v15 DFU Bootloader hangs on execute instruction
Hi, I'm migraing our project to the latest NRF5 SDK v15.0.0 (S132  v6.0.0). We were previously on v12.2.0  (S132 v3.0.0) using the BLE DFU Bootloader. I've  modified our bootloader code to match the example from the latest SDK. It compiles and runs on our board. We're using our own utility which implements the DFU procedure to upload the firmware to our device.
The utility is able to connect, switch the device to the bootloader and transfer the init packet. The problem arises when the first object has been transferred and  we issue an execute command. The device locks up and doesn't respond to any command (including the execute). If I break with gdb the cpu is always somewhere around address `0x0007c1ea`. It is a branch instruction to the same address... an infinite loop.
I tried the nRF Toolbox for Android, but it wasn't even able to switch to the bootloader. I assume it hasn't been updated to use the new 16-bit Buttonless Servicee UUID.
Is there any obvious reason  this could be happening?
