Multiple GATT read with RedBear Nano (nRF52)
Hi! I'm using two RedBear Nano v2 and I'm trying to read a long characteristic from one of the two devices. As I read in other posts in the forum, I need to invoke the read method multiple times with increasing offsets in order to read the entire characteristic. However, if I invoke the read method multiple times, it seems that only the callback regarding the last read is executed.
Do you have any suggestion on how can I address this issue?
Thanks in advance for the help.
    That sounds strange. Are you checking the return code of sd_ble_gattc_read()? Make sure that you wait for a BLE_GATTC_EVT_READ_RSP after every call to sd_ble_gattc_read(), before you start new read operation. Otherwise sd_ble_gattc_read() should return NRF_ERROR_BUSY.
    If that isn't the problem, can you show us how you perform the read operations? And what SDK and Softdevice version are you using?
