I build ADC example from SDK12.3.0 for nRF51822 QFAA chip from source. I used custom board and changed the pin configuration for UART logging in sdk_config.h file.
But unfortunately after programming the chip with compiled file there is no result on minicom.
Here is my custom_board.h and sdk_config.h files:
#ifndef TEST_BOARD_H
#define TEST_BOARD_H
#ifdef __cplusplus
extern "C" {
#include "nrf_gpio.h"
#define LEDS_NUMBER 1
#define LED_RGB_RED 16
#define LEDS_ACTIVE_STATE 0
#define LEDS_LIST { LED_RGB_RED }
#define LEDS_INV_MASK LEDS_MASK
#define BSP_LED_0 LED_RGB_RED
#define BUTTONS_NUMBER 1
#define BUTTON_1 11
#define BUTTON_PULL NRF_GPIO_PIN_PULLUP
#define BUTTONS_LIST { BUTTON_1 }
#define BUTTONS_ACTIVE_STATE 0
#define BSP_BUTTON_0 BUTTON_1
#ifdef __cplusplus
#ifndef SDK_CONFIG_H #define SDK_CONFIG_H // <<< Use Configuration Wizard in Context Menu >>>\n #ifdef USE_APP_CONFIG #include "app_config.h" #endif // <h> nRF_Drivers //========================================================== // <e> ADC_ENABLED - nrf_drv_adc - Driver for ADC peripheral (nRF51) //========================================================== #ifndef ADC_ENABLED #define ADC_ENABLED 1 #endif #if ADC_ENABLED // <o> ADC_CONFIG_IRQ_PRIORITY - Interrupt priority // <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice // <0=> 0 (highest) // <1=> 1 // <2=> 2 // <3=> 3 #ifndef ADC_CONFIG_IRQ_PRIORITY #define ADC_CONFIG_IRQ_PRIORITY 3 #endif // <e> ADC_CONFIG_LOG_ENABLED - Enables logging in the module. //========================================================== #ifndef ADC_CONFIG_LOG_ENABLED #define ADC_CONFIG_LOG_ENABLED 0 #endif #if ADC_CONFIG_LOG_ENABLED // <o> ADC_CONFIG_LOG_LEVEL - Default Severity level // <0=> Off // <1=> Error // <2=> Warning // <3=> Info // <4=> Debug #ifndef ADC_CONFIG_LOG_LEVEL #define ADC_CONFIG_LOG_LEVEL 3 #endif // <o> ADC_CONFIG_INFO_COLOR - ANSI escape code prefix. // <0=> Default // <1=> Black // <2=> Red // <3=> Green // <4=> Yellow // <5=> Blue // <6=> Magenta // <7=> Cyan // <8=> White #ifndef ADC_CONFIG_INFO_COLOR #define ADC_CONFIG_INFO_COLOR 0 #endif // <o> ADC_CONFIG_DEBUG_COLOR - ANSI escape code prefix. // <0=> Default // <1=> Black // <2=> Red // <3=> Green // <4=> Yellow // <5=> Blue // <6=> Magenta // <7=> Cyan // <8=> White #ifndef ADC_CONFIG_DEBUG_COLOR #define ADC_CONFIG_DEBUG_COLOR 0 #endif #endif //ADC_CONFIG_LOG_ENABLED // </e> #endif //ADC_ENABLED // </e> // <e> PERIPHERAL_RESOURCE_SHARING_ENABLED - nrf_drv_common - Peripheral drivers common module //========================================================== #ifndef PERIPHERAL_RESOURCE_SHARING_ENABLED #define PERIPHERAL_RESOURCE_SHARING_ENABLED 0 #endif #if PERIPHERAL_RESOURCE_SHARING_ENABLED // <e> COMMON_CONFIG_LOG_ENABLED - Enables logging in the module. //========================================================== #ifndef COMMON_CONFIG_LOG_ENABLED #define COMMON_CONFIG_LOG_ENABLED 0 #endif #if COMMON_CONFIG_LOG_ENABLED // <o> COMMON_CONFIG_LOG_LEVEL - Default Severity level // <0=> Off // <1=> Error // <2=> Warning // <3=> Info // <4=> Debug #ifndef COMMON_CONFIG_LOG_LEVEL #define COMMON_CONFIG_LOG_LEVEL 3 #endif // <o> COMMON_CONFIG_INFO_COLOR - ANSI escape code prefix. // <0=> Default // <1=> Black // <2=> Red // <3=> Green // <4=> Yellow // <5=> Blue // <6=> Magenta // <7=> Cyan // <8=> White #ifndef COMMON_CONFIG_INFO_COLOR #define COMMON_CONFIG_INFO_COLOR 0 #endif // <o> COMMON_CONFIG_DEBUG_COLOR - ANSI escape code prefix. // <0=> Default // <1=> Black // <2=> Red // <3=> Green // <4=> Yellow // <5=> Blue // <6=> Magenta // <7=> Cyan // <8=> White #ifndef COMMON_CONFIG_DEBUG_COLOR #define COMMON_CONFIG_DEBUG_COLOR 0 #endif #endif //COMMON_CONFIG_LOG_ENABLED // </e> #endif //PERIPHERAL_RESOURCE_SHARING_ENABLED // </e> // <e> UART_ENABLED - nrf_drv_uart - UART/UARTE peripheral driver //========================================================== #ifndef UART_ENABLED #define UART_ENABLED 1 #endif #if UART_ENABLED // <o> UART_DEFAULT_CONFIG_HWFC - Hardware Flow Control // <0=> Disabled // <1=> Enabled #ifndef UART_DEFAULT_CONFIG_HWFC #define UART_DEFAULT_CONFIG_HWFC 0 #endif // <o> UART_DEFAULT_CONFIG_PARITY - Parity // <0=> Excluded // <14=> Included #ifndef UART_DEFAULT_CONFIG_PARITY #define UART_DEFAULT_CONFIG_PARITY 0 #endif // <o> UART_DEFAULT_CONFIG_BAUDRATE - Default Baudrate // <323584=> 1200 baud // <643072=> 2400 baud // <1290240=> 4800 baud // <2576384=> 9600 baud // <3862528=> 14400 baud // <5152768=> 19200 baud // <7716864=> 28800 baud // <10289152=> 38400 baud // <15400960=> 57600 baud // <20615168=> 76800 baud // <30924800=> 115200 baud // <61865984=> 230400 baud // <67108864=> 250000 baud // <121634816=> 460800 baud // <251658240=> 921600 baud // <268435456=> 57600 baud #ifndef UART_DEFAULT_CONFIG_BAUDRATE #define UART_DEFAULT_CONFIG_BAUDRATE 30924800 #endif // <o> UART_DEFAULT_CONFIG_IRQ_PRIORITY - Interrupt priority // <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice // <0=> 0 (highest) // <1=> 1 // <2=> 2 // <3=> 3 #ifndef UART_DEFAULT_CONFIG_IRQ_PRIORITY #define UART_DEFAULT_CONFIG_IRQ_PRIORITY 3 #endif // <q> UART_EASY_DMA_SUPPORT - Driver supporting EasyDMA #ifndef UART_EASY_DMA_SUPPORT #define UART_EASY_DMA_SUPPORT 1 #endif // <q> UART_LEGACY_SUPPORT - Driver supporting Legacy mode #ifndef UART_LEGACY_SUPPORT #define UART_LEGACY_SUPPORT 1 #endif // <e> UART0_ENABLED - Enable UART0 instance //========================================================== #ifndef UART0_ENABLED #define UART0_ENABLED 1 #endif #if UART0_ENABLED // <q> UART0_CONFIG_USE_EASY_DMA - Default setting for using EasyDMA #ifndef UART0_CONFIG_USE_EASY_DMA #define UART0_CONFIG_USE_EASY_DMA 1 #endif #endif //UART0_ENABLED // </e> // <e> UART_CONFIG_LOG_ENABLED - Enables logging in the module. //========================================================== #ifndef UART_CONFIG_LOG_ENABLED #define UART_CONFIG_LOG_ENABLED 1 #endif #if UART_CONFIG_LOG_ENABLED // <o> UART_CONFIG_LOG_LEVEL - Default Severity level // <0=> Off // <1=> Error // <2=> Warning // <3=> Info // <4=> Debug #ifndef UART_CONFIG_LOG_LEVEL #define UART_CONFIG_LOG_LEVEL 3 #endif // <o> UART_CONFIG_INFO_COLOR - ANSI escape code prefix. // <0=> Default // <1=> Black // <2=> Red // <3=> Green // <4=> Yellow // <5=> Blue // <6=> Magenta // <7=> Cyan // <8=> White #ifndef UART_CONFIG_INFO_COLOR #define UART_CONFIG_INFO_COLOR 0 #endif // <o> UART_CONFIG_DEBUG_COLOR - ANSI escape code prefix. // <0=> Default // <1=> Black // <2=> Red // <3=> Green // <4=> Yellow // <5=> Blue // <6=> Magenta // <7=> Cyan // <8=> White #ifndef UART_CONFIG_DEBUG_COLOR #define UART_CONFIG_DEBUG_COLOR 0 #endif #endif //UART_CONFIG_LOG_ENABLED // </e> #endif //UART_ENABLED // </e> // </h> //========================================================== // <h> nRF_Log //========================================================== // <e> NRF_LOG_ENABLED - nrf_log - Logging //========================================================== #ifndef NRF_LOG_ENABLED #define NRF_LOG_ENABLED 1 #endif #if NRF_LOG_ENABLED // <e> NRF_LOG_USES_COLORS - If enabled then ANSI escape code for colors is prefixed to every string //========================================================== #ifndef NRF_LOG_USES_COLORS #define NRF_LOG_USES_COLORS 0 #endif #if NRF_LOG_USES_COLORS // <o> NRF_LOG_COLOR_DEFAULT - ANSI escape code prefix. // <0=> Default // <1=> Black // <2=> Red // <3=> Green // <4=> Yellow // <5=> Blue // <6=> Magenta // <7=> Cyan // <8=> White #ifndef NRF_LOG_COLOR_DEFAULT #define NRF_LOG_COLOR_DEFAULT 0 #endif // <o> NRF_LOG_ERROR_COLOR - ANSI escape code prefix. // <0=> Default // <1=> Black // <2=> Red // <3=> Green // <4=> Yellow // <5=> Blue // <6=> Magenta // <7=> Cyan // <8=> White #ifndef NRF_LOG_ERROR_COLOR #define NRF_LOG_ERROR_COLOR 0 #endif // <o> NRF_LOG_WARNING_COLOR - ANSI escape code prefix. // <0=> Default // <1=> Black // <2=> Red // <3=> Green // <4=> Yellow // <5=> Blue // <6=> Magenta // <7=> Cyan // <8=> White #ifndef NRF_LOG_WARNING_COLOR #define NRF_LOG_WARNING_COLOR 0 #endif #endif //NRF_LOG_USES_COLORS // </e> // <o> NRF_LOG_DEFAULT_LEVEL - Default Severity level // <0=> Off // <1=> Error // <2=> Warning // <3=> Info // <4=> Debug #ifndef NRF_LOG_DEFAULT_LEVEL #define NRF_LOG_DEFAULT_LEVEL 3 #endif // <e> NRF_LOG_DEFERRED - Enable deffered logger. // <i> Log data is buffered and can be processed in idle. //========================================================== #ifndef NRF_LOG_DEFERRED #define NRF_LOG_DEFERRED 0 #endif #if NRF_LOG_DEFERRED // <o> NRF_LOG_DEFERRED_BUFSIZE - Size of the buffer for logs in words. // <i> Must be power of 2 #ifndef NRF_LOG_DEFERRED_BUFSIZE #define NRF_LOG_DEFERRED_BUFSIZE 256 #endif #endif //NRF_LOG_DEFERRED // </e> // <q> NRF_LOG_USES_TIMESTAMP - Enable timestamping // <i> Function for getting the timestamp is provided by the user #ifndef NRF_LOG_USES_TIMESTAMP #define NRF_LOG_USES_TIMESTAMP 0 #endif #endif //NRF_LOG_ENABLED // </e> // <h> nrf_log_backend - Logging sink //========================================================== // <o> NRF_LOG_BACKEND_MAX_STRING_LENGTH - Buffer for storing single output string // <i> Logger backend RAM usage is determined by this value. #ifndef NRF_LOG_BACKEND_MAX_STRING_LENGTH #define NRF_LOG_BACKEND_MAX_STRING_LENGTH 256 #endif // <o> NRF_LOG_TIMESTAMP_DIGITS - Number of digits for timestamp // <i> If higher resolution timestamp source is used it might be needed to increase that #ifndef NRF_LOG_TIMESTAMP_DIGITS #define NRF_LOG_TIMESTAMP_DIGITS 8 #endif // <e> NRF_LOG_BACKEND_SERIAL_USES_UART - If enabled data is printed over UART //========================================================== #ifndef NRF_LOG_BACKEND_SERIAL_USES_UART #define NRF_LOG_BACKEND_SERIAL_USES_UART 1 #endif #if NRF_LOG_BACKEND_SERIAL_USES_UART // <o> NRF_LOG_BACKEND_SERIAL_UART_BAUDRATE - Default Baudrate // <323584=> 1200 baud // <643072=> 2400 baud // <1290240=> 4800 baud // <2576384=> 9600 baud // <3862528=> 14400 baud // <5152768=> 19200 baud // <7716864=> 28800 baud // <10289152=> 38400 baud // <15400960=> 57600 baud // <20615168=> 76800 baud // <30924800=> 115200 baud // <61865984=> 230400 baud // <67108864=> 250000 baud // <121634816=> 460800 baud // <251658240=> 921600 baud // <268435456=> 57600 baud #ifndef NRF_LOG_BACKEND_SERIAL_UART_BAUDRATE #define NRF_LOG_BACKEND_SERIAL_UART_BAUDRATE 30924800 #endif // <o> NRF_LOG_BACKEND_SERIAL_UART_TX_PIN - UART TX pin #ifndef NRF_LOG_BACKEND_SERIAL_UART_TX_PIN #define NRF_LOG_BACKEND_SERIAL_UART_TX_PIN 13 #endif // <o> NRF_LOG_BACKEND_SERIAL_UART_RX_PIN - UART RX pin #ifndef NRF_LOG_BACKEND_SERIAL_UART_RX_PIN #define NRF_LOG_BACKEND_SERIAL_UART_RX_PIN 12 #endif // <o> NRF_LOG_BACKEND_SERIAL_UART_RTS_PIN - UART RTS pin #ifndef NRF_LOG_BACKEND_SERIAL_UART_RTS_PIN #define NRF_LOG_BACKEND_SERIAL_UART_RTS_PIN 15 #endif // <o> NRF_LOG_BACKEND_SERIAL_UART_CTS_PIN - UART CTS pin #ifndef NRF_LOG_BACKEND_SERIAL_UART_CTS_PIN #define NRF_LOG_BACKEND_SERIAL_UART_CTS_PIN 14 #endif // <o> NRF_LOG_BACKEND_SERIAL_UART_FLOW_CONTROL - Hardware Flow Control // <0=> Disabled // <1=> Enabled #ifndef NRF_LOG_BACKEND_SERIAL_UART_FLOW_CONTROL #define NRF_LOG_BACKEND_SERIAL_UART_FLOW_CONTROL 0 #endif // <o> NRF_LOG_BACKEND_UART_INSTANCE - UART instance used // <0=> 0 #ifndef NRF_LOG_BACKEND_UART_INSTANCE #define NRF_LOG_BACKEND_UART_INSTANCE 0 #endif #endif //NRF_LOG_BACKEND_SERIAL_USES_UART // </e> // <e> NRF_LOG_BACKEND_SERIAL_USES_RTT - If enabled data is printed using RTT //========================================================== #ifndef NRF_LOG_BACKEND_SERIAL_USES_RTT #define NRF_LOG_BACKEND_SERIAL_USES_RTT 0 #endif #if NRF_LOG_BACKEND_SERIAL_USES_RTT // <o> NRF_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE - RTT output buffer size. // <i> Should be equal or bigger than \ref NRF_LOG_BACKEND_MAX_STRING_LENGTH. // <i> This value is used in Segger RTT configuration to set the buffer size // <i> if it is bigger than default RTT buffer size. #ifndef NRF_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE #define NRF_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE 512 #endif #endif //NRF_LOG_BACKEND_SERIAL_USES_RTT // </e> // </h> //========================================================== // </h> //========================================================== // <h> nRF_Segger_RTT //========================================================== // <h> segger_rtt - SEGGER RTT //========================================================== // <o> SEGGER_RTT_CONFIG_BUFFER_SIZE_UP - Size of upstream buffer. #ifndef SEGGER_RTT_CONFIG_BUFFER_SIZE_UP #define SEGGER_RTT_CONFIG_BUFFER_SIZE_UP 64 #endif // <o> SEGGER_RTT_CONFIG_MAX_NUM_UP_BUFFERS - Size of upstream buffer. #ifndef SEGGER_RTT_CONFIG_MAX_NUM_UP_BUFFERS #define SEGGER_RTT_CONFIG_MAX_NUM_UP_BUFFERS 2 #endif // <o> SEGGER_RTT_CONFIG_BUFFER_SIZE_DOWN - Size of upstream buffer. #ifndef SEGGER_RTT_CONFIG_BUFFER_SIZE_DOWN #define SEGGER_RTT_CONFIG_BUFFER_SIZE_DOWN 16 #endif // <o> SEGGER_RTT_CONFIG_MAX_NUM_DOWN_BUFFERS - Size of upstream buffer. #ifndef SEGGER_RTT_CONFIG_MAX_NUM_DOWN_BUFFERS #define SEGGER_RTT_CONFIG_MAX_NUM_DOWN_BUFFERS 2 #endif // </h> //========================================================== // </h> //========================================================== // <<< end of configuration section >>> #endif //SDK_CONFIG_H
