nRF Toolbox DFU only app not working as intended.
I was given the source code to the nRF Toolbox DFU only app in order to implement its functionality within my own app. Using the nRF Connect app, I've connected to my hardware and enabled DFU mode. I then switched over to the DFU only app and attempted to upload new firmware which I then received the "DFU Service Not Found" error. And, the upload then fails.
Is there any further advice you can give on setting up a self contained app to enabled DFU and upload, all within the same app?
I need build an app that may have a disconnect while performing an update, currently I am unable to recover using my own software if this happens. Using nRF Connect, if an update is stopped, it can be resumed once a reconnection is established. I would like to use the nRF Toolbox DFU Only app as an example so I can do this the correct way. Please advise.
Thank you
