Device is not supported. Check if it is in the DFU state.
Hi!
When trying to update app using example bootloader for s110, v.7 from nRF Toolbox I get "Device is not supported. Check if it is in the DFU state".
Bootloader is runing (checked with debuger).
Output from Master Control Panel:
[19:50:28.3] Connected to address: E5EFA36A2E9D
[19:50:28.3] Starting a Read Information Request on the whole remote DB
[19:50:28.3] Received Connection Parameter Update Request
[19:50:28.3] ConnectionParameterUpdateResponse sent with ACCEPTED response
[19:50:28.3] Connection Parameters Update sent. ConnInterval:15.0ms, SlaveLatency:0, SupervisionTimeout:4000.0ms
[19:50:28.6] Discovering all attribute UUIDs
[19:50:28.6] {'UUID': 10240}
[19:50:28.6] Received a Service group UUID
[19:50:28.6] {'UUID': 10243}
[19:50:28.6] Received a Characteristic Group group UUID
[19:50:28.6] {'UUID': 10752}
[19:50:28.6] Received a Characteristic Group group attribute
[19:50:28.6] {'UUID': 10753}
[19:50:28.6] {'UUID': 10756}
[19:50:28.6] {'UUID': 429897603425982122840792728654115L}
[19:50:28.6] {'UUID': 429818375263467858503199184703779L}
[19:50:28.6] {'UUID': 10498}
[19:50:28.6] Discovering all attribute values
[19:50:28.6] Received Read Response, handle: 0x0001, value (0x): 00-18
[19:50:28.7] Received Read Response, handle: 0x0002, value (0x): 0A-03-00-00-2A
[19:50:28.7] Received Read Response, handle: 0x0003, value (0x): 42-6C-65-42-6F-78
[19:50:28.7] Received Read Response, handle: 0x0004, value (0x): 02-05-00-01-2A
[19:50:28.8] Received Read Response, handle: 0x0005, value (0x): 00-00
[19:50:28.8] Received Read Response, handle: 0x0006, value (0x): 02-07-00-04-2A
[19:50:28.8] Received Read Response, handle: 0x0007, value (0x): 0C-00-18-00-00-00-90-01
[19:50:28.9] Received Read Response, handle: 0x0008, value (0x): 01-18
[19:50:28.9] Received Read Response, handle: 0x0009, value (0x): 23-D1-BC-EA-5F-78-23-15-DE-EF-12-12-30-15-00-00
[19:50:28.9] Received Read Response, handle: 0x000A, value (0x): 04-0B-00-23-D1-BC-EA-5F-78-23-15-DE-EF-12-12-32-15-00-00
[19:50:29.0] Received Error Response: READ_NOT_PERMITTED, handle: 0x000B
[19:50:29.0] Received Read Response, handle: 0x000C, value (0x): 18-0D-00-23-D1-BC-EA-5F-78-23-15-DE-EF-12-12-31-15-00-00
[19:50:29.0] Received Error Response: READ_NOT_PERMITTED, handle: 0x000D
[19:50:29.1] Received Read Response, handle: 0x000E, value (0x): 00-00
[19:50:29.1] Service Discovery complete
[19:50:29.9] Over-the-air DFU using C:\Program Files (x86)\Nordic Semiconductor\Master Emulator\2.1.8.8331\MasterEmulator.dll
[19:51:24.1] Over-the-air DFU started
[19:51:36.6] Data could not be sent - failed!!!
[19:51:37.8] Loading...
[19:51:37.8] Over-the-air DFU completed
[19:51:38.2] Ready
[19:51:38.3] SERVER: Server has started
[19:51:38.3] Device address: 0xB9BC11438248
[19:51:38.3] Master emulator firmware version: mefw_nrf51822_0.9.0.10022
How can I fix it?
Cheers, Patriko
