Address Discrepances between Debugging and nrfjprog memrd
Introduction
I use fStorage to write some data to flash and I read the data by following procedure:
    uint32_t Read32(uint32_t address)
        return *(mpFlashConfig->p_start_addr + address);
All seamed working correctly. But then I tried to read some addresses with nrfjprog and I only go zeros.
Analysis
I have two data section with each one page and according debugger (Visual Studio, VisualGDB, GCC 7.2.0)
  • Section A
    • mpFlashConfig->p_start_addr = 0x6'8000
    • address = 0x4c00
    • sum = 0x6'cc00
  • Section B
    • address = 0x5000
    • sum = 0x6'cc00
When I search memory with nrfjprog memrd, then I find the test words (written in page start address) in following addresses:
  • Section A: 0x7'B000
  • Section B: 0x7'C000
Obviously, these addresses do not match. As far as I know, the nrfjprog uses Byte-Addresses. 0x4c00 must be a word address because bytes-size of page is 0x1000 (4096). p_start_addr is an uint32_t const pointer, so far I suppose it is also a word address. Muliplying the sum of both together is still a different address than detected by nrfjprog.
Do you have any idea, what fails here?
Versions and Tools
I use Softdevice S132 v3.0.0 and SDK v12.3.
The code is executed on nRF52823_CIAA with 512 kB Flash.
Further, nrfjprog 9.7.1 is used.
