Write Application Data to Flash with pstorage
i am having trouble to understand and use flash to store data. First of all as far as i understand ble_flash is obsolete and replaced by the pstorage module, correct?
What i want to achieve is, i want to save user settings to flash to be able to set my system to the same state after it has been e.g. reset. Therefore i need to write, erase, read and update existing settings to/in flash.
I read the following documentation part and used it as base of my own code: devzone.nordicsemi.com/.../a00018.html
Do i need to change any addresses in pstorage_platform to match it to my application? I was not sure whether i need to change code in pstorage_platform or not so i didn't changed anything.
The coded i copied from the documentation and the code i added is shown in the file attached.
The pstorage_init is called in my init_app_data_flash_manager function and after the ble_stack_init. Futhermore pstorage_init is called only once.
    // Initialize in main
leds_init();
timers_init();
gpiote_init();
buttons_init();
ble_stack_init();
init_app_data_flash_manager();
scheduler_init();
gap_params_init();
services_init();
advertising_init();
conn_params_init();
sec_params_init();
My code does the following like descibed in the documentation. I register one block with specific size (in bytes) after pstorage_init. The handle generated while registering is saved and later used to read/write to get a block_handle using pstorage_block_identifier_get. Afterwards this block handle is used to read/write using pstorage_load and pstorage_store.
To test all this I write and read to flash after my device is disconnected (see BLE_GAP_EVT_DISCONNECTED). I also stop adversting to read and write to flash so radio should be inactiv.
            //advertising_start();
			//test_app_system_settings is empty, test data is generated in save_settings_to_flash
					save_settings_to_flash(&test_app_system_settings);
					read_settings_from_flash(&test_app_system_settings);
When i debug it the array i read in read_settings_from_flash is empty (just zero).
Can anyone tell me what i am doing wrong and/or help me get it working?
Regards
code.c
Edit: I almost forgot the maybe most importat thing: How do I manage to read and write to the same address every time cause the address i wrote to in the first place is gone after a reset and saving it to flash is not possible cuase this would require a address i dont know after reset as well?
  • Have a look at this module as well (Device Manager) devzone.nordicsemi.com/.../a00937.html . It should take quite good care of what you're trying to do.
  • Thanks Christian. I already took a look at it and i got to say it is a lot of code and thus hard to get trough. I added the update function to my save_setting function but stiil get no results.
  • 2. EDIT: Just to confirm whether i get this right or not. If my application hits one of the op code states below in my param.cb = app_data_flash_manager_cb_handler implementation registered with pstorage_register(&param,&handle_base). Then i know an error occured when i e.g. tried to load data from flash. Correct??? Cause apperantly i hit them all the time so i guess not a single operation i try to exec works/is successful.
    OP CODE: #define PSTORAGE_ERROR_OP_CODE 0x01
    #define PSTORAGE_STORE_OP_CODE 0x02
    #define PSTORAGE_LOAD_OP_CODE 0x03
    #define PSTORAGE_CLEAR_OP_CODE 0x04
    #define PSTORAGE_UPDATE_OP_CODE 0x05 Regards
  • I don't know how are You using pstorage module, but in my case (which i consider as correct) it works like this:
    1. I flash my code do device
    2. I store some data in pstorage (after blank check - if not empty, erase before write), and read it back succesfully
    3. I flash my device with new code.
    4. I can read data stored by previous application succesfully
    5. In nrf studio i use "erase all"
    6. i cannot read data anymore.
    I think your implementation may miss something like getting the same flash memory block as previous one.
  • How do you get the same flash block? My app performs the following operations everytime it gets switched on:
    // init pstorage module
    err_code = pstorage_init();
    // register flash space in pstorage module
    param.block_size = 64;
    param.block_count = 1;
    param.cb = app_data_flash_manager_cb_handler;
    err_code = pstorage_register(&param,&handle_base);
    I am not sure but i assumed i will get the same flash part if the size i request is the same everytime.
