where is NRFX_PWM0_INST_IDX defined in SDK 15?
I'm attempting to build a project to use easyDMA with PWM,    but as there are no applicable examples in SDK 15, I am working on it myself.  I originally asked for help here: https://devzone.nordicsemi.com/f/nordic-q-a/33473/using-sdk-15-0-and-pca10040-would-like-to-create-a-repeating-sawtooth-waveform-using-pwm-and-easydma
but didn't get any responses so I am converting a code example that I referenced in my previous post to be compatible with SDK 15.
I've currently got one build error caused by NRFX_PWM0_INST_IDX being undefined.
   It's used in line 78 of nrfx_pwm.h    (see line 21 below)
 * @brief PWM driver instance data structure.
typedef struct
    NRF_PWM_Type * p_registers;  ///< Pointer to the structure with PWM peripheral instance registers.
    uint8_t        drv_inst_idx; ///< Driver instance index.
} nrfx_pwm_t;
 * @brief Macro for creating a PWM driver instance.
#define NRFX_PWM_INSTANCE(id)                               \
    .p_registers  = NRFX_CONCAT_2(NRF_PWM, id),             \
    .drv_inst_idx = NRFX_CONCAT_3(NRFX_PWM, id, _INST_IDX), \
enum {
#if NRFX_CHECK(NRFX_PWM0_ENABLED)
    NRFX_PWM0_INST_IDX,
#if NRFX_CHECK(NRFX_PWM1_ENABLED)
    NRFX_PWM1_INST_IDX,
#if NRFX_CHECK(NRFX_PWM2_ENABLED)
    NRFX_PWM2_INST_IDX,
#if NRFX_CHECK(NRFX_PWM3_ENABLED)
    NRFX_PWM3_INST_IDX,
    NRFX_PWM_ENABLED_COUNT
I don't think I'm missing any include files, does anyone have some hints?    You won't find anything mentioning this value anywhere!
Here is my current code, which is an example I found which I converted to be compatible with SDK 15:
// for PWM
#include <stdio.h>
#include "nrfx_pwm.h"
#include "app_error.h"
#include "boards.h"
#include "bsp.h"
#include "app_timer.h"
#include "nrf_drv_clock.h"
#include "nrf_delay.h"
// other items for PWM
#define OUTPUT_PIN 26
#define DUTY_A 50
#define DUTY_B 80
#define NRFX_PWM0_INST_IDX 0        // <<-- just added this as it was undefined
static nrfx_pwm_t m_pwm0 = NRFX_PWM_INSTANCE(0);
static nrf_pwm_values_common_t /*const*/ seq0_values[] =
DUTY_A,DUTY_A,DUTY_A
nrf_pwm_sequence_t const seq0 =
.values.p_common = seq0_values,
.length = NRF_PWM_VALUES_LENGTH(seq0_values),
.repeats = 0,
.end_delay = 0
static nrf_pwm_values_common_t /*const*/ seq1_values[] =
DUTY_B,DUTY_B,DUTY_B,DUTY_B,DUTY_B,DUTY_B,DUTY_B
nrf_pwm_sequence_t const seq1 =
.values.p_common = seq1_values,
.length = NRF_PWM_VALUES_LENGTH(seq1_values),
.repeats = 36,
.end_delay = 0
static void pwm_init(void)
nrfx_pwm_config_t const config0 =
.output_pins =
OUTPUT_PIN, // channel 0
NRFX_PWM_PIN_NOT_USED, // channel 1
NRFX_PWM_PIN_NOT_USED, // channel 2
NRFX_PWM_PIN_NOT_USED, // channel 3
.irq_priority = APP_IRQ_PRIORITY_LOWEST,
.base_clock = NRF_PWM_CLK_1MHz,
.count_mode = NRF_PWM_MODE_UP,
.top_value = 100,
.load_mode = NRF_PWM_LOAD_COMMON,
.step_mode = NRF_PWM_STEP_AUTO
// Init PWM without error handler
APP_ERROR_CHECK(nrfx_pwm_init(&m_pwm0, &config0, NULL));
// end PWM
// and here is main()
/**@brief Function for application main entry.
bool erase_bonds;
// Initialize modules.
log_init();
clock_init();
#ifdef TRC_USE_TRACEALYZER_RECORDER
#if (TRC_CFG_RECORDER_MODE == TRC_RECORDER_MODE_STREAMING)
vTraceEnable(TRC_INIT);
#else
vTraceEnable(TRC_START);
// Do not start any interrupt that uses system functions before system initialisation.
// The best solution is to start the OS before any other initalisation.
#if NRF_LOG_ENABLED
// Start execution.
if (pdPASS != xTaskCreate(logger_thread, "LOGGER", 256, NULL, 1, &m_logger_thread))
APP_ERROR_HANDLER(NRF_ERROR_NO_MEM);
// Activate deep sleep mode.
SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
// Configure and initialize the BLE stack.
ble_stack_init();
timers_init();
gap_params_init();
gatt_init();
advertising_init();
services_init();
sensor_simulator_init();
conn_params_init();
peer_manager_init();
application_timers_start();
BattChn=xTraceRegisterString("Battery Level");
RateChn=xTraceRegisterString("Heart Rate");
// PWM
// Start clock for accurate frequencies
// Wait for clock to start
while(NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
pwm_init();
APP_ERROR_CHECK(nrfx_pwm_complex_playback(&m_pwm0, &seq0, &seq1, 1,
NRFX_PWM_FLAG_LOOP ));
// end PWM
// Create a FreeRTOS task for the BLE stack.
// The task will run advertising_start() before entering its loop.
nrf_sdh_freertos_init(advertising_start, &erase_bonds);
NRF_LOG_INFO("HRS FreeRTOS example started.");
// Start FreeRTOS scheduler.
vTaskStartScheduler();
for (;;)
APP_ERROR_HANDLER(NRF_ERROR_FORBIDDEN);
Currently, the linker is giving these two errors:
Any ideas?
