Using:
- nRF51822
- GCC 4.8.4
- Nordic Sdk 5.2.0
- and even Ole Morten's nice pure-gcc setup
- newlib-nano and -flto
Within the startup_nrf51.s I found something like this.
Sdk:
#ifdef __STACK_SIZE
.equ Stack_Size, __STACK_SIZE
#else
.equ Stack_Size, 2048
#ifdef __HEAP_SIZE
.equ Heap_Size, __HEAP_SIZE
#else
.equ Heap_Size, 2048
Pure Gcc:
#ifdef __STACK_SIZE
#else
.equ Stack_Size, 0xc00
#ifdef __HEAP_SIZE
#else
.equ Heap_Size, 0x100
This looks as there are some hard coded default values for Stack and Heap size inside of the startup assembler sources. Now I wonder, what's the way to override the default values (without modifying the startup assembler sources).
Well, CFLAGS+=-D__STACK_SIZE=1024 would not work, because CFLAGS is not applied for the assembler call.
But also if I try to extend the assembler command line to something like this:
arm-none-eabi-as --defsym __STACK_SIZE=0x0800 ../../../../HaalandSetup/template/startup_nrf51.s -o _build/startup_nrf51.os
won't help. The reason seems to be, that arm-none-eabi-as completely ignores the c-style preprocessor statements (#ifdef ...). He sees both .equ Stack_Size, __STACK_SIZE and .equ Stack_Size, 0xc00 and uses just the last seen assignment.
Then I try to invoke gcc preprocessor like this:
arm-none-eabi-gcc -x assembler-with-cpp ../../../../HaalandSetup/template/startup_nrf51.s -o _build_SensorDevboard/startup_nrf51.os
but I failed with some curios errors ("undefined reference to _exit" ...).
Finally, I'd made it work with the following modifications:
- In
startup_nrf51.s, changing all#ifdefet cetera to.ifdef - In pure-gcc
Makefile, changing$(AS) $< -o $@to$(AS) $(AFLAGS) $< -o $@
And now, I'm able to add in my project specific Makefile something like:
AFLAGS += --defsym __STACK_SIZE=0x0800
to get project specific control over that.
Now the question: Is this the right way to get project specific control over stack and heap size or did I something wrong and failed to see the prefered way?
I'd just playing around with some different values for __HEAP_SIZE and __STACK_SIZE.
- If I set them too big (e.g. both to
0x5000), then I earn what I expectld: region RAM overflowed with stack. - Then I set
__HEAP_SIZEto e.g.0x0100, callmalloc(4000)in my program and expect themalloc()to fail but it succeeds. - And then setting
__STACK_SIZEto e.g.0x0010and expecting my program to crash because running out of stack but it works regardless which value I assign for__STACK_SIZE.
So for me it looks, that assigning __STACK_SIZE and __HEAP_SIZE was not the right way to control stack and heap size, isn't it?
Edit 2014-08-27: After some further investigation I found the following curious facts:
__HEAP_SIZEand__STACK_SIZEwill generate symbols like__StackLimitand__HeapLimit__StackLimitand__HeapLimitare only checked at link time (may generate an assert "region RAM overflowed with stack")- at runtime neither
__StackLimitnor__HeapLimitare recognized __StackLimitdon't raise any e.g. "stack overflow exception" when stackpointer is passing bymalloc()won't interesting for__HeapLimit(and also not for__StackLimit!)- Highly dangerous:
malloc()grab all memory up to the current position of the stackpointer (yes, the stackpointer position at the time of the malloc call). This means that malloc takes takes memory that I'd tried to reserved for the Stack! → Strange behaviour …
Edit 2014-08-30: Solved the »malloc() grab my Stack« issue
With this tiny custom _sbrk() implementation, I teach malloc() to take care of __HeapLimit:
void* _sbrk(ptrdiff_t incr) {
extern uint32_t __HeapBase;
extern uint32_t __HeapLimit;
static char* heap = 0;
if (heap == 0) heap = (char*)&__HeapBase;
void* ret = heap;
if (heap + incr >= (char*)&__HeapLimit)
ret = (void*)-1;
heap += incr;
return ret;
Note that _sbrk() required to return (void*)-1 to indicate that we are out of memory (see here and here). When returning (void*)0 instead, it will end up in a hardfault.
In my setup, I need to spend at least 1468 Byte heap space (within the startup_nrf51.s) to make printf & co work.
Giving just 436 Byte will also work, but slows down the output performance (because stdio will work unbuffered). write() is then called for each single character to output. When writing to uart with 1 MBaud, its about factor 2 slower!
Giving less than 436 Byte heap space results in a hardfault at the first time when printf / puts / putchar was called.
When both ram size and speed matters, we can adjust the stdout buffersize by calling setvbuf() (see here) before the 1st printf / puts / putchar call like this:
static char stdoutBuffer[40];
setvbuf(stdout, stdoutBuffer, _IOLBF, sizeof(stdoutBuffer));
printf("Hello …");
In this way, we prevent that stdio allocates it's 1 KiB buffer but uses that provided 40 Byte buffer instead.
Note that the given values may depend one the used toolchain version.
