Right now I have a program on nRF52-DK (SDK 11) that scans for BLE adv packets, and transfers data from some specific addresses to PC through UART. Around every 10ms there is 30 bytes of new data to be transferred. In the current program, the UART transfer is within the same function that is called whenever there is a new BLE packet received. This program is running fine.
Now, I want to eliminate the UART->PC parts, and write to a SD card instead. While I'm waiting to receive the required hardware, I tried to look for SD card examples. So, here are what I found and my questions about the feasibility of what I'm trying to implement:
The closest example I found is from Jorgen in post1 . This is the ble_app_uart_fatfs, which combines the ble_uart example and the FATFS for SD card. The difference is that it's not for continuous writing to the file (data logging), as it closes the file at the end of the write. Again, based on Ole's answer in post2, it seems the better practice is to use f_sync after each f_write and leave the file open.
The main concern here is that as writing to the SD card might take a long time around 250-500 ms, what will happen to the BLE scan that needs to scan all the time and update data every 10ms. What I understand from Pawel's answer in post3 is that
- FATFS is using SPI master in EasyDMA mode; so does that mean if BLE writes to Buffer1 and FATFS transfers Buffer2, SD card operation won't affect BLE scanning?
- we need to call FATFS API in the main context; My BLE scanning also starts from the main, but before any FATFS operation; and radio interrupt has the highest priority, so SD operation should not block the radio. Right?
- In post3 he says: "However, when there is a serial data transfer in the background (card read/write operation), higher priority interrupts should not affect SD communication (except the possible delay), as far as SPI driver interrupts are being handled."
So, considering my application, what is this delay? If it's caused by the BLE scan, then that needs to run all the time. So will it block the SD operation?
I'm not familiar with the fine details of the EasyDMA, but my assumption is that as it doesn't need the CPU, so probably CPU is free to do the scanning and when they are working on to different buffers (memory spaces), they should not block each other.
(I know that FATFS example is from SDK 12.2 and I need to move my code to at least 12.2 to use the example, but hopefully that shouldn't be a big deal).
