I am begineer coder. I am working on nRF52832 board. Want to develope firmware for Temperature and Humidity using HTU21D sensor. Could anyone provide me complete code with supporting files to refer. thanks.
I am working on nRF52832 controller for a small project . I am completely new to this series of controller.
I want to develope a firmware to measure Humidity and Temperature using HTU21D sensor. I am using Eclipse neon IDE. I am completely unaware of procedure to develope a code using Eclipse IDE.
Could anyone please send me a complete code to measure Humidity and Temperature using HTU21D. Please I want code and supporting files for the same. e.g. linker file, makefile, configuration file etc.
Thanks in advance!
  • hi,
      here i attach the code for htu21d but it works in pca10028. you want to make necessary changes to work on nrf52832 pca 10040. 2526.HTU21D.rar
    cheers,
    karthikeyan
  • Hi Karthikeyan,
    I do have another query. I have done my coding for another project. Please help me to rectify the code.
    I am sumitting the code here.
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include "app_uart.h"
    #include "app_error.h"
    #include "nrf_delay.h"
    #include "nrf.h"
    #include "bsp.h"
    #define MAX_TEST_DATA_BYTES     (15U)
    #define UART_TX_BUF_SIZE 256
    #define UART_RX_BUF_SIZE 256
    //  UART error handler function.
    void uart_error_handle(app_uart_evt_t * p_event)
        if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
        else if (p_event->evt_type == APP_UART_FIFO_ERROR)
    // LED glow function: When data Transmitted is equal to data Received then LED glow up else stays off.
    void led_blink()
        bsp_board_leds_init();
        while (true)
            for (int i = 0; i < 1; i++)
                bsp_board_led_invert(i);
                nrf_delay_ms(500);
    //   UART transmit function.
     #if ((Enable_UART_TxDecimalNumber==1) || (Enable_UART_TxFloatNumber==1))
    void UART_Tx(uint32_t dec_no, uint8_t nod)
    		uint8_t i=0;
    		printf("\nEnter decimal no to transmit:");
    		scanf("\n%d", &dec_no);
    		if(dec_no==0)																			//decimal number to transmit
    			for(i=0; ((i<nod) && (i<max_dttx)); i++)											//number of digits to transmit
    			a[i] = 0x00;																		//maximum number of digits to transmit
    		else if
    			for(i=0; i<nod; i++)
    				if(dec_no!=0)
    					a[i] = util_GetMod32(dec_no,10);
    					dec_no = dec_no/10;
    		else if( (nod == dttx) || (nod > max_dttx))												//total numbers to transmit
    				a[i]=0;
    	while(i)
    		UART_TxChar(util_Dec2Ascii(a[i-1]));													//Convert decimal to ASCII
    		i--;
    	void led_blink();
    //  main Function.
        uint32_t err_code;
        const app_uart_comm_params_t comm_params =
              RX_PIN_NUMBER,
              TX_PIN_NUMBER,
              RTS_PIN_NUMBER,
              CTS_PIN_NUMBER,
              APP_UART_FLOW_CONTROL_ENABLED,
              false,
              UART_BAUDRATE_BAUDRATE_Baud19200
                             UART_RX_BUF_SIZE,
                             UART_TX_BUF_SIZE,
                             uart_error_handle,
                             APP_IRQ_PRIORITY_LOWEST,
                             err_code);
        UART_Tx();
    	return 0;
    I want to transmit 0-9 numbers using UART. Above the code for same. I dont know where I am going wrong. Please help me with code.
  • hi,
      can you post the new question. because anybody can answer that. and also please describe the exact problem
  • Yes Karthikeyan, I will do the same.
    Thank you for suggestion. Appericiate!
