Error: L6915E:
hi,
   i am using sdk 14.1 nrf52840.
i am getting these 2 errors in keil
.\_build\nrf52840_xxaa.axf: Error: L6915E: Library reports error: __use_no_heap was requested, but malloc was referenced
.\_build\nrf52840_xxaa.axf: Error: L6915E: Library reports error: __use_no_heap was requested, but free was referenced
but i am not getting these errors in ses. how to solve this in keil?
regards,
karthikeyan
    What example are you compiling?
    Do you have the file \examples\802_15_4\experimental\wireless_uart\retarget.c in your project, or a file that includes the line "#pragma import(__use_no_heap)" in your project?
    Håkon
  • hi hakon,
       i am using ble_proximity example as a base and developed my own application.
    i have commented this two line
    #pragma import(__use_no_heap_region)
    from retarget.c file.
    now it is compiling with out error.
    is this the correct format what i have done or is there any other option.
    regards,
    karthikeyan
  • I recommend using the retarget.c file from this folder: \components\libraries\uart\
    The one that you have included now (from the path examples\802_15_4\experimental\wireless_uart) is just an empty implementation.
    I do not see why this pragma is needed in the retarget.c file, or why this file is included at all.
    If this is required by some corner-case in our code base, it should still be wrapped around #pragma push and #pragma pop, like this:
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    #pragma push
    /* functions and declarations */
    // Pop the options to ensure they're only valid for this file
    #pragma pop
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    I'll input this as a bug internally.
    Håkon
