Receiving for UART with FreeRTOS
I have implemented a somewhat working RX algorithm for receiving data over UART but I'm looking for a good way to make it more robust. I haven't found any good answers to this in either the forum or the infocenter and I get a little bit confused regrading the driver setup.
My implementation:
  • Custom board using nRF52840
  • Using the nRF5 SDK v15.0.0.
  • Using FreeRTOS, built from the "ble_app_hrs_freertos"-example. (At the moment without BLE stack initialization.)
  • Implemented FreeRTOS task for handling UART communication.
  • Have a module connected over UART that use AT-commands.
Assumptions:
  • As it is AT-commands I always know the ending of the message, though I don't know the length as the reply to one command can be different.
    • An example is reading the ID which gives 24 bytes as answer. If there is a failure, the answer is simply "+ERR=x".
    • There is a response to every TX, thus I want to have RX after TX.
So far I have tried mostly with the "Serial port library" and I have tried using blocking-mode similar to:
uint32_t received_bytes = 0;
err = nrf_serial_write(&serial_uart, tx_tmp, tx_size, NULL, NRF_SERIAL_MAX_TIMEOUT);
err = nrf_serial_read(&serial_uart, rx_tmp, 50, &received_bytes, 100);
This does however only work for the first message. The second time I try with nrf_serial_read() I get an error as the handle for the timer is not null, somewhere around line 136 in app_timer_freertos.c (DUH, it is already created). For experimentation I changed to the following in app_timer_create() function in app_timer_freertos.c and now it works (even though I know it is a VERY ugly solution):
    if (pinfo->osHandle == NULL)
        /* New timer is created */
        memset(pinfo, 0, sizeof(app_timer_info_t));
        if (mode == APP_TIMER_MODE_SINGLE_SHOT)
            timer_mode = pdFALSE;
            timer_mode = pdTRUE;
        pinfo->func = timeout_handler;
        pinfo->osHandle = xTimerCreate(" ", 1000, timer_mode, pinfo, app_timer_callback);
            err_code = NRF_ERROR_NULL;
        xTimerReset(pinfo->osHandle, 100);
        /* Timer cannot be reinitialized using FreeRTOS API */
        //return NRF_ERROR_INVALID_STATE;
So is this a bug or am I using it totally wrong? Is the approach of using software timers good, or should I change to some other method?
Regards
Robert
  • I have also found issues when using the app_timer when I know the exact amount of bytes, i.e. I know that I will recieve 10 bytes and thus I set:
    err = nrf_serial_read(&serial_uart, tmp_rx, 10, &received_bytes, 100);
    The problem at this stage is that the timer is actually not reset when the correct amount of bytes are recieved. I think an "app_timer_stop(*p_serial->p_rx_timer);" should be set also when the expected byte count is recieved such as:
    do
            size_t rcnt = serial_rx(p_serial, p_buff, left);
            left -= rcnt;
            p_buff += rcnt;
            if (!left)
                (void)app_timer_stop(*p_serial->p_rx_timer);
            if (tout_ctx.expired)
                if (p_serial->p_ctx->p_config->mode != NRF_SERIAL_MODE_POLLING)
                    nrf_drv_uart_rx_abort(&p_serial->instance);
            sleep_handler(p_serial);
        } while (1);
    In nrf_serial_read() function approx at line 460 to 479 in nrf_serial.c.
    I guess there should be a check if the timer is active before trying to stop it, or maybe that doesn't matter...?
    I am sorry to see that this has been left unanswered for so long.
    I have tried to look into these issues, but I am afraid I need some help from a colleague who is out-of-office and will be so for the next two weeks. Hopefully I can come back to you before that, but that I cannot guarantee.
    From what I can tell thus far, yes, your proposed workaround in the opening post looks ugly, and I would find it very strange if something like that should be necessary. Are you sure that you have configured the serial port library correctly?
    We might need your full project, at least more code, in order to set up, reproduce and investigate further. You may open a private case in order to do so, if confidential. In that case please refer to this thread.
    Terje
  • Hello Terje,
    Yes, as I said in my post I am aware the solution is very ugly, it was more for demonstrating what the problem was rather than proposing a solution.
    I'm mainly looking for a solution of the problem and I'm really confused to what I should use. Is the recommended driver to use for UART the UARTE module in the NRFX-part of the SDK? I.e. "nRF5_SDK_15.0.0\modules\nrfx\drivers\src\nrfx_uarte.c"
    If you are interested in deeper knowledge of the problem I have encountered I can share the code in a private case. But if you can recommend another module/library to use I will look more into that solution instead. My super ugly solutions work for now, and I'm only working with a PoC so I will not spend to much time to find a proper fix.
    Regards
    Robert
    I see.
    One third of the Norwegian public holidays are in May this year, so our capacity is reduced this month. I suggest that you stick to the solution you have right now for the proof of concept, and I will come back to you as soon as everyone is back in office. As these issues involves both FreeRTOS and the new SDK (with the new nrfx wrappers) I am afraid I have to discuss with several others who are not here at the moment in order to give good advice.
    Terje
    Was this issue ever resolve? I am having the same issue with the SDK-15.2.0
