SDK 15 peer_manager undefined reference ble_evt_handler
Migrating from 13.1 to 15.0.
getting error, undefined reference to 'ble_evt_handler'
In 15.0, peer_manager.c has the function,
In 15.0, ble_conn_params.c has the same function name (but with a switch statement),
In SES I have the peer and conn objects in the nRF_BLE folder, and in edit options the preprocessor user include directories.
When looking at these same two functions in 13.1, there are differences to 15.0;
In 13.1, peer_manager.c ,
void pm_on_ble_evt(ble_evt_t const * p_ble_evt)
In 13.1, ble_conn_params.c,
void ble_conn_params_on_ble_evt(ble_evt_t const * p_ble_evt)
(this change had already taken place when looking at 14.2)In 13.1,
peer_manager.c ,
Was this change intentional?
In the Migration Guide(s), I do not see a note about this change (unless I missed it) to help understand.
-thank-you
  • FormerMember
    0 FormerMember
    Do you have enabled the connection parameter module in sdk_config.h?
  • I had the connection parameter already enabled.
    there are other undefined errors as well,
    this is from an attempt to get this tutorial and this code working with sdk15.0.
  • FormerMember
    0 FormerMember in reply to Simon
    Does the declaration of the function in the .h files matches the implementation in the .c files? And does that declaration match the one in the documentation?
  • Looks like the questions are a starting point in updating the tutorial (which has now gone missing, but comments remain).
    I found these tutorials extremely helpful (and others have probably as well), and now with 15.0 there seem to have been some big changes. To add, SES is being encouraged, and s112 with nRF52810 are out (which I'm using for custom), and having the tutorials in sync helps to understand these changes.
    I'm still not sure why the function names are the same in 15.0, whereas in 13.1 the functions were named differently. A & B different function names and code, C & D same function name but same code as A & B.
    A) 13.1   peer_manager.h
    void pm_on_ble_evt(ble_evt_t * p_ble_evt)
        VERIFY_MODULE_INITIALIZED_VOID();
        im_ble_evt_handler(p_ble_evt);
        sm_ble_evt_handler(p_ble_evt);
        gcm_ble_evt_handler(p_ble_evt);
    B) 13.1  ble_conn_params.h
    void ble_conn_params_on_ble_evt(ble_evt_t * p_ble_evt)
            case BLE_GAP_EVT_CONNECTED:
                on_connect(p_ble_evt);
                on_disconnect(p_ble_evt);
            case BLE_GATTS_EVT_WRITE:
                on_write(p_ble_evt);
            case BLE_GAP_EVT_CONN_PARAM_UPDATE:
                on_conn_params_update(p_ble_evt);
                // No implementation needed.
    C) 15.0   peer_manager.h
    D) 15.0  ble_conn_params.h
  • FormerMember
    Did you were able to solve the "undefined reference" problem?
    I don't know why the names of all the ble event handlers in the different modules were changed to ble_evt_handler(..), perhaps it was to easier get an overview..?
