I'm trying to enable TWI in the eddystone example based on this article but I get the following compilation error:
nrfx/legacy/nrf_drv_twi.h:120:37: error: 'NRF_DRV_TWI_INSTANCE_0' undeclared here (not in a function)
main.c#include "nrf_drv_twi.h" #define TWI_INSTANCE_ID 0 static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
sdk_config.h
//========================================================== #ifndef NRFX_TWI_ENABLED #define NRFX_TWI_ENABLED 1 #endif // <q> NRFX_TWI0_ENABLED - Enable TWI0 instance #ifndef NRFX_TWI0_ENABLED #define NRFX_TWI0_ENABLED 1 #endif #ifndef TWI_ENABLED #define TWI_ENABLED 1 #endif // <e> TWI0_ENABLED - Enable TWI0 instance //========================================================== #ifndef TWI0_ENABLED #define TWI0_ENABLED 1 #endif // <q> TWI0_USE_EASY_DMA - Use EasyDMA (if present) #ifndef TWI0_USE_EASY_DMA #define TWI0_USE_EASY_DMA 1 #endif // </e> //========================================================== #ifndef NRFX_TWIM_ENABLED #define NRFX_TWIM_ENABLED 1 #endif // <q> NRFX_TWIM0_ENABLED - Enable TWIM0 instance #ifndef NRFX_TWIM0_ENABLED #define NRFX_TWIM0_ENABLED 1 #endif
Added nrf_drv_twi.c to the project.
I can compile the twi_sensor project so the issue must be in the configs.
Should I add anything else into the sdk_config.h to make the TWI work?
