How Can I Use Dır_Mask Pin Read?
I have a lot of pin_read function. How can i set all port one line? for example P1OUT = (P1.01 | P1.02 | P1.03) or P1IN = (P1.01 | P1.02 | P1.03) I dont know how to use pin mask?
here is my code and header file;
#include <stdbool.h>
#include <stdint.h>
#include "boards.h"
#include "nrf_delay.h"
#include "nrf_gpio.h"
#include "nrf.h"
#include "nrf_drv_gpiote.h"
#include "app_error.h"
#include "nrf_drv_timer.h"
#include "app_timer.h"
#include "app_button.h"
#include "nrf_drv_ppi.h"
#include "nrf_fstorage.h"
#include "nordic_common.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "ble_lbs.h"
#include "nrf_ble_gatt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "Tus_Tarama_Deneme.h"
void Sutun_Cikislari(void)
  nrf_gpio_cfg_output(LED_DENEME);
  nrf_gpio_cfg_output(SUTUN_1);
  nrf_gpio_cfg_output(SUTUN_2);
  nrf_gpio_cfg_output(SUTUN_3);
  nrf_gpio_pin_set(SUTUN_1);
  nrf_gpio_pin_set(SUTUN_2);
  nrf_gpio_pin_set(SUTUN_3);
  nrf_gpio_cfg_input(SATIR_1, NRF_GPIOTE_POLARITY_LOTOHI);
  nrf_gpio_pin_read(SATIR_1);
  nrf_gpio_cfg_input(SATIR_2, NRF_GPIOTE_POLARITY_LOTOHI);
  nrf_gpio_pin_read(SATIR_2);
  while(1)
    if(nrf_gpio_pin_read(SATIR_1)  || nrf_gpio_pin_read(SATIR_2))
      nrf_gpio_pin_set(LED_DENEME);
      nrf_gpio_pin_clear(LED_DENEME);
#define SUTUN_1       25
#define SUTUN_2       20
#define SUTUN_3       18
#define SATIR_1       16
#define SATIR_2       15
#define SATIR_3       14
#define SATIR_4       12
#define SATIR_5       10
#define LED_DENEME    24
  • Note that
    is not completely identical to
    if (NRF_GPIO->IN & ((1UL << SATIR_1) | (1UL << SATIR_2)))
    because the code below only reads the IN register once.
    One can set the output value of several pins using NRF_GPIO->OUT, but you can only set the mode of each pin individually, as each has its own mode register.
  • Hello everyone;
    thanks for answer I tried this and it worked. Then i changed someting in my code. But pins out it was not set high. I want to know where is my mistake?
    unsigned char sutunlar;
      sutunlar = NRF_GPIO->OUT & ((1UL << SUTUN_1) | (1UL << SUTUN_2) | (1UL << SUTUN_3));
    //  nrf_gpio_cfg_output(SUTUN_1);
    //  nrf_gpio_cfg_output(SUTUN_2);
    //  nrf_gpio_cfg_output(SUTUN_3);
    //  nrf_gpio_pin_set(SUTUN_1);
    //  nrf_gpio_pin_set(SUTUN_2);
    //  nrf_gpio_pin_set(SUTUN_3);
      nrf_gpio_pin_set(sutunlar);
  • You are trying to put waaay more than 8 bits into your "unsigned char sutunlar;" variable. Try uint32_t type.
  • uint32_t sutunlar;
      while(1)
    here is my new code but it didn't happend.
    this line is correct?
  • Why don't you check this yourself with a debugger? I have absolutely no idea what this line is supposed to do. It has correct C syntax and masks out everything but the 3 port bits.
